anyone using a breather oil cap?
Old Jul 25, 2008 | 04:12 PM
VGLNTE1's Avatar
Default anyone using a breather oil cap?
i did the catch can and the fresh air tube from the CAI to the valve cover. oil is shooting up into the aie bridge. my tuner said to cap the intake and use a breather oil cap and ditch the fresh air tube to the valve cover...anyone do that?
Old Jul 25, 2008 | 04:36 PM
3.4camaro's Avatar
Yip. I ditched the PCV system for a breather. Gets rid of wires, makes the bay look cleaner, and no oil in the intake.
Only downside is that you lose like 1-2hp because the PCV sucks air out of the crankcase, so the rotating assembly doesn't have to work against as much air.
Old Jul 28, 2008 | 09:36 AM
chadnol10's Avatar
you mean if you put a breather in you can delete your pcv system? explain
Old Jul 28, 2008 | 09:39 AM
Rapter34's Avatar
is there any link to this swap or do you just remove all the PCV system, cap the intake and put a breather on?
Old Jul 28, 2008 | 10:53 AM
VGLNTE1's Avatar
i waas told to cap the intake. get a catchcan with a breather on it and have that go to teh LS3 style PCV port out of the valley and then T a line to the valve cover
Old Jul 28, 2008 | 10:59 AM
chadnol10's Avatar
any pics of all this?
Old Jul 28, 2008 | 02:40 PM
VGLNTE1's Avatar
i havent done it yet
Old Jul 28, 2008 | 03:46 PM
3.4camaro's Avatar
I bought a $5 breather from o'rielley's and put it on where one of the pcv hoses goes into the valve cover. Then I ran a hose to connect the 2 valve covers and siliconed close all other hoses/ports going from the valve covers, TB, and intake.
FWI I also don't have the EVAP system.
Old Jul 28, 2008 | 09:34 PM
Haans249's Avatar
I have been thinking about this for a while....
Take the following two pictures...
The first picture has the PCV valve coming out the intake
The second picture has the PCV valve coming out of the valley cover to the top of the can...
The first picture has the restriction of the PCV valve being close (blowing from the nipple side/sucking from the non-nipple side) coming out of the catch can into the intake.
The second picture doesn't have that restriction (sucking from the nipple side/blowing from the flat side) into the catch can and straight into the intake.
Which one is the right way? lol. BTW, these are pictures from Mikenorrismotorsports.com and their catch-can setup that I'm going to be purchasing.
Thanks
Attached Thumbnails anyone using a breather oil cap?-dsc00900.jpg   anyone using a breather oil cap?-dsc01027.jpg
Old Jul 28, 2008 | 10:02 PM
VGLNTE1's Avatar
they are both the same. the way I have it now. but on the dyno, you should have seen the oil i was eating.....retarded
Old Jul 28, 2008 | 10:08 PM
j99fbody's Avatar
i ditched the pvc and put a breather on both valve covers
Old Jul 28, 2008 | 11:13 PM
Haans249's Avatar
Um, those are not the same AT ALL. Look at it again.
One, the PCV valve is backwards, and the other it is the right way. But which one is the right way? You probably have yours backwards and thats why you were eating so much oil haha.
Old Jul 28, 2008 | 11:20 PM
VGLNTE1's Avatar
the top line in both pics are going TO the valley, both lines on bottom are going TO the intake
Old Jul 29, 2008 | 12:06 AM
Haans249's Avatar
Dude... look at the PCV valve, and re-read my first post. Its quite obvious that the lines are going the same way, but what is different is the location of the VALVE itself, and the direction with which it is being run. One way is the wrong way, the other is the right way, I believe the first pic has it right, and the second pic has it backwards.
Old Jul 29, 2008 | 08:56 AM
OUTLAWZ RACING's Avatar
Thanks
The pics to me shows it will just suck the oil back in the intake. I see the line from the valley cover, thats is on top ,then the line that is on the intake that is on the bottom. When the oil drips hell it will get suck back in the intake if its baffeld or not. If you use a vacum source it should be higher then drip lines,so all its sucking is vapors. I would just run a baffeld catch can with a breather, That will keep oil out the intake better.
Old Jul 29, 2008 | 09:02 AM
Haans249's Avatar
http://www.mikenorrismotorsports.com...atch_Cans.html
The way it is designed, i don't think it'll suck up any oil vapors, it has a filter inside and everything, looks like a super quality piece.
Old Jul 29, 2008 | 04:11 PM
VGLNTE1's Avatar
HAHHAHA . Dude... look at the PCV valve, and re-read my first post. Its quite obvious that the lines are going the same way, but what is different is the location of the VALVE itself, and the direction with which it is being run. One way is the wrong way, the other is the right way, I believe the first pic has it right, and the second pic has it backwards.
ah, you dont need that **** either.
Old Jul 29, 2008 | 04:12 PM
VGLNTE1's Avatar
that is the can i have...with filters inside....it sucks oil. I am going for a breather one
Old Jul 29, 2008 | 04:32 PM
Haans249's Avatar
So you're saying that you're not running the PCV valve? Ever thought about putting it back on and seeing how much oil you then use? If you have this catch can, I don't see how you could be sucking up oil through it. It is baffled AND has filters.
Post a picture of what you're running right now, I'm curious....whether I want to run a catch can now.
Old Jul 31, 2008 | 02:35 AM
Troux's Avatar
Are there any oil breather caps that go right into the valve cover, as opposed to sticking out through the FRC?
