how big of a bore on LSX block
LSX Bowtie Block (Standard Deck)
• 3.990" finished siamese cylinder bores
(ready to be honed to your specifications)
• 9.26" semi-finished standard deck height
(ready to be decked to your specifications)
• Max 4.250" recommended stroke
• Capable of 364 to 482+ cid
• Orange powder coat finish
• Accepts all Gen III & IV LS heads, cranks, cams, etc.
• Approximate finished weight: 225 lbs.
For the advanced LSX competition engine builder, you will
fully enjoy reading the following features of the new LSX
Bowtie Block:
• Front oil feed holes can be plugged/restricted for mechanical
flat tappet or mechanical roller lifter applications
• Can be machined safely to 9.20" deck height
• Main bearing cap bolt threads can be machined for aftermarket
premium 12mm fasteners
• Maximum 4.250" bore at .200" minimum wall thickness
(naturally aspirated applications)
• 6-bolt head bolt pattern (for boosted applications)
• Machined for 8mm inner and outer 5th and 6th head bolts
• Standard bolt holes can be machined for 1/2" studs
• Cam bores can be machined to accept 60mm roller bearings
• Can be machined for larger diameter lifters and/or 1.060"
bronze bushings
• Front oil feed lines can be plugged and external oil pump
and/or aftermarket dry sump systems can be used via oil
pump feed at rear of block—may be required with certain
large stroke/aluminum rod combinations
• Belt cam drive systems can be accommodated—some
machining will be required
• External oil pump feed at rear of block
• 7th transmission bolt hole has been added (per early SBC), stud
can be installed for sanctioning body requirements
• Front motor plate can be used for racing chassis applications
(sprint car, drag racing, truck pulling, etc.)
• Threaded water plugs can be used for external heaters or coolers
Going bigger than the 4" stroke on FI or n2o isn't ideal. For big FI application we go with a 434, 4.155 bore and 4" stroke max. So anything in between that would be good taking shelf piston size into account unless your going with a custom piston. If I can help you please let know.
Bowtie Block:
bronze bushings
(naturally aspirated applications) ok so what would be the biggest for ((turbo charged applications)) that's why im asking this question is that a problem??
4.175 Bore x 4.000 Stroke 438"
106mm Turbo
@ 13# makes 1100hp
@ 25psi runs 191mph at 3350lbs
Talk to someone whos done it like me....Or 4 or 5 other guys in this section. Personally, I going to a cleanup of 4.190 bore/4" stroke. althou its not optimum, i'm limiting boost, and running 6 bolt heads w/L19's
Personall I woul not exceed 4.125"/4.0" on a high boost motor. This give you a ton of meat not only in the cylinder walls, but keeps the material above the rings.
BYW, I agree on your 4" idea. I just pulled my 4.125, and went 4.0"
Hell, he "works" for Ford..
Ban..Ban...Ban...Ban..
Phil, Shoot me a PM and the young one status..
Call me when you get a chance. We build boosted applications all the time.
4" stroke is the longest you want on a boosted or N2o LS engine, unless you using the LS7 block ( but then you have the sleeve issue..LOL)
Because it's not a typical build or a dumbass question.
