ls2 with ls7 dry sump newbie question
Old Aug 24, 2008 | 04:44 PM
68topls's Avatar
Default ls2 with ls7 dry sump newbie question
Looking to run a ls7 dry sump system using ATS's dry sump pan. Just wanted to clarify that I only need to add the ls7 front cover, pump and breather tanks to swap to the dry sump?
Old Aug 24, 2008 | 05:05 PM
LSX Wizard's Avatar
You're going to have to buy a long snout crankshaft too. The LS7 oil pump drive is about an inch longer to accommodate the second stage. Once you put the longer drive on, you no longer have any snout left to slip the damper on.
