LS3 into 98TA
Old Sep 23, 2008 | 08:42 AM
8802flhtci's Avatar
Default LS3 into 98TA
Will my stock wiring and ecm work with the new GMPP 480 hp LS3 crate motor? I know the LS3 is fly by wire and that will have to be addressed. Thanks Dave
Old Sep 26, 2008 | 04:01 PM
DrkPhx's Avatar
The LS3 has a 58x crank reluctor wheel and the LS1 is 24x. So the stock LS1 crank sensor and PCM are not compatible with a stock LS3 crank. In addition, the cam sensor is mounted in the front timing cover and the MAP sensor is different and mounted on the front of the LS3 intake. The knock sensors for the LS3 are not mounted in the engine valley like the LS1, but on each side of the block. You can overcome those with a little ingenuity or buy aftermarket adaptor harnesses, but the crank reluctor wheel does present a problem IF you use the stock crank.
