[PRESS RELEASE] Katech Performance Air Attack LS7 SC (Supercharged) Crate engine
McCullough Public Relations
330.244.9980
KATECH PERFORMANCE ANNOUNCES 'AIR ATTACK' LS7 SUPERCHARGED ENGINE PACKAGE
CLINTON TOWNSHIP, Mich. - Katech Performance has announced its "Air Attack" LS7 SC (Supercharged) crate engine is available for owners of hot rods, off-road vehicles and show cars.
The 427 cubic-inch displacement (4.125-inch bore; 4.000-inch stroke) engine produces up to 750 horsepower and 700 ft.-lbs. of massive stump-pulling, flat-lined torque. Katech lays a solid foundation with Callies forged steel crankshaft and connecting rods plus the manufacturer's forged aluminum pistons with DLC (Diamond-Like Carbon) coated pins. They use a stock LS7 block with a billet steel girdle to tie the bottom end together.
"Our Air Attack LS7 SC delivers extreme forced-induction performance for the LS7 engine in off-road and hot-rodding applications," said Caleb Newman, vice president, director aftermarket operations, Katech Performance. "Because we are producing 50 percent more power - far beyond what the cast production piston was designed for - our Katech forged pistons were a must in the Air Attack LS7 SC to maintain engine life and enable even greater boost levels."
An upgraded camshaft designed for boost actuates the stock LS7 titanium intake valve and sodium-filled exhaust valves. Magnuson handles the compression of the air change with their M122 twin-screw high-helix intercooled supercharger. In addition to the standard features, optional Katech valve covers and TVS-based superchargers are also available.
The engine is one of five that make up Katech Performance's LS7 "Arsenal" that includes a "Street Attack" LS7 7.0L, "Sneak Attack" LS7 5.7L, "Desert Attack" LS7 7.0L and "Track Attack" LS7 7.0L option. Each engine is completely disassembled, blueprinted and enhanced by the same technicians that produce championship winning engines for all Katech race programs.
Since 1977, Katech has captured more than 50 driver's and manufacturer's championships competing in the world's most prestigious racing leagues, including the SCCA SPEED World Challenge, American Speed Association (ASA), International Motor Sports Association (IMSA), American Le Mans Series (ALMS) and NASCAR(r).
For more information or to request a catalog, call 866-KATECH1 or visit Katech Performance online at www.katechengines.com.
Katech Performance, the aftermarket performance division of Katech Inc., engineers and manufactures race-proven crate engines and components for LS1/LS6 and LS2/LS7 engines including solid belt tensioners, coil relocation brackets, cylinder heads, dampers, pistons, push rods, throttle bodies and valve covers, among other high-performance products for the street and track.
Katech Inc. was founded on the need to provide responsive service and skills to factory race efforts in all forms of racing, including the SCCA SPEED World Challenge GT, NASCAR and the American Le Mans Series. Today, Katech is an industrial leader in advanced racing and high-performance engine development, manufacturing, testing and assembly, and offers support services for the professional racer including boring, honing, fabrication, welding and prototype parts development.
Katech Performance is located at 24324 Sorrentino Court, Clinton Township, MI, 48035. Contact the company by phone at 866-KATECH1 or visit online at www.katechengines.com.
Katech Air Attack LS7 SC Fast Facts:
Application: Hot rods, off-road vehicles, show cars
Displacement: 427ci, 7.0L
Bore: 4.125
Stroke: 4.000
Compression ratio: 9.0-10.0:1
Fuel: 93 octane
Boost: 7-10psi
Horsepower: 700-750
Torque: 675-700
Block: LS7 with stud girdle and ARP studs
Heads: LS7 with ARP studs
Crank: Callies forged steel
Connecting rods: Callies H-Beam forged steel
Pistons: Katech forged aluminum with DLC coated pins
Camshaft: Katech Air Attack LS7 SC
Oiling system: LS7 dry sump
Supercharger: Magnuson M122 twin-screw high-helix, intercooled
Throttle body: 105mm cable
Optional Katech valve covers shown
$25k if you supply the LS7
That includes the complete supercharger kit to install it in a car.
90 day warranty on Katech workmanship for crate engines
12mo/12000mi warranty on vehicle installations. It would have to be a 1970 or earlier muscle car to install it at Katech though (emissions purposes).
To answer your question on warranty, its not really an issue. We've never had an engine warranty claim. I guess that goes to show that properly engineered and validated packages don't even need a warranty, but we offer them anyways for piece of mind.
To answer your question on if the engine "lets go" internally, lets look at a couple of hypothetical situations. If you were to break a piston due to a defect in that piston and you are within 90 days, the engine would be covered. If you were to break a piston due to a defect and it has been 91 days, I'm sure we're not going to say sorry about your luck pal. We're reasonable people. If you were to have this engine installed at a local shop and you broke a piston due to detonation from improper calibration, that would not be covered under warranty.
If you compare our prices to other top builders such as Lingenfelter, we are right in line. We take a look at the market and try to price things as competitively as possible. To engineer some of the most cutting edge packages in the world, the costs are quite high. We do not cut any corners. We buy the best parts possible if not make them ourselves from scratch, and we validate everything we do with thousands of hours of engineering time. As a result, we have a very high level of customer satisfaction. We have found a customer base which holds a high value for the services and level of quality we offer.
A large part of the 500 cubic inch engine is the Dart billet block as you mentioned. I just don't understand how you are comparing the price of a cast aluminum short block to a billet completely dressed engine.
I am not saying the Dart block is the same as the warhawk, but you have to agree they are both premium blocks that wil handle anything you can throw at em and give many many years of reliable service. But I do see your point round 9000k for the Dart block and 4500k for the warhawk.
I know you're a fan and I appreciate that, but your first post did sound a little harsh. I want things to be affordable as possible but costs are very high on some things. We try to diversify our packages to suit a wide range of audiences and I would love to build an engine for you. We can do a LS7 based, Warhawk, or LSX for you and I'm sure we can find something to suit your needs and budget.
Keep in mind that the Dart billet block for $9000 that you mentioned is the one sold directly from Dart. We made 32 design changes from that to make the 500.
~725 FWHP = about 580 RWHP through an A4...right? (20% loss)
Nice engine but man you can build two amazing N/A 454's for that price though.
