HElP Crank install
Old Oct 14, 2008 | 07:44 PM
deftones22's Avatar
Default Another Crank install Question
Hello you all my question to you all which i hope can be answered .
Can you install a ls1 crank off a 2000 motor into a 2000 6.0 block and if so is there any modifications that are needed or direct fitment please help this would be greatly appreciated .. The reason for this install purchased the 6.0 short block for 350 thinking it was a great deal then while reading the forum it stated the crank was longer than the stock ls1 and i am using a 4l60 off a 2000 camaro so you see my predicament ..
Old Oct 14, 2008 | 09:01 PM
ddcarter's Avatar
Some of the earlier 6.0 cranks are longer on the rear crankshaft flange. If you are using the car transmission I do not think this will be an issue.
Old Oct 14, 2008 | 09:08 PM
deftones22's Avatar
i have mounted the transmission to the block and the converter didnt have any play whick i couldnt move the t/c to bolt it to the flywheel ..the area was to snugged ...which on the ls1 that is not an issue
Old Oct 14, 2008 | 09:10 PM
ddcarter's Avatar
Dumb question, but was the torque convertor seated in the tranny fully?
Old Oct 14, 2008 | 09:16 PM
ddcarter's Avatar
Just reread this. I thought you were asking if the LS1 crank will work. The 6.0 crank is probably about 0.400 inch to long to make it work with the older style transmissions. If you swap out the crank it should work. Make sure to use the correct reluctor wheel for your application.
Old Oct 14, 2008 | 10:47 PM
deftones22's Avatar
yes it was...thanks for the reply....i have the stock ls1 crank with the reluctor wheel that came with it. Will this work?
Old Oct 14, 2008 | 11:06 PM
ddcarter's Avatar
What PCM are you going to be running?
Old Oct 14, 2008 | 11:11 PM
deftones22's Avatar
from the stock ls1
deftones22's Avatar
2000 camaro to be more precise
Old Oct 14, 2008 | 11:15 PM
ddcarter's Avatar
That should work fine.
deftones22's Avatar
also will the stroke be the same or would there be any complications that would require balancing or anything just being percautious
Old Oct 15, 2008 | 11:24 AM
ls1290's Avatar
Dumb Ass Vette Moderator
The rotating assembly will need to be rebalanced since different sized pistons will be used.
Old Oct 15, 2008 | 11:28 AM
Ice78Transam's Avatar
x2. Don't forget this!
Old Oct 15, 2008 | 12:38 PM
deftones22's Avatar
thank you all for your replys this has been very helpful ......
Old Oct 15, 2008 | 05:27 PM
deftones22's Avatar
also what main bearings will i need to use and rod bearings .. i was told by a local machine shop that the main journals wouldnt fit please is there anyone that i can contact that has done the same swap same block and crank .. i am so stressed out with this and work and trying to finish grad school
Old Oct 15, 2008 | 07:36 PM
ddcarter's Avatar
I would go to a different shop. I far as I know all the journals rod and mains are the same. That goes for all LS series engines. I just put an Lunati LS1 crank in a LS7 block.
Old Oct 15, 2008 | 07:40 PM
Joey316G's Avatar
The mains and rod bearings are the same.
Old Oct 15, 2008 | 11:30 PM
deftones22's Avatar
thanks guys i really appreciate the info i would appreciate anymore input thank you all
Old Oct 15, 2008 | 11:56 PM
ddcarter's Avatar
What is the intended purpose of this engine? Is it a mild build or just a rebuild?
Old Oct 16, 2008 | 12:08 AM
deftones22's Avatar
well i have a ms3 going in the motor with built heads all bolt ons
