If I ordered an LS3 block will I get a 2009?
It's important since there are suppose to be significant improvements in 2009.
Thanks
I had heard that the quality of the prior LS3 blocks have been suspect (the LS2's have been better).
It does have a temp part #xxxxx982 and is not yet available. There is a note that some of the previously compatible parts will not interchange so at this point you do not want the New version.
The info is as of 10/22/08
-Geoff
The LS9 blocks are different in that they have oil jet feeds to spray the undersides of the piston crowns for cooling, as well as durability improvements.
The use of increased radii (from 3mm to 8mm) in the hone overtravel area started around the last quarter of 07, and then went to 10mm for LS9, as did the LS7 style radius on the bay to bay breathing slot edges: durability improvement as well as a stiffness improvement, as the increased radii improve fatigue strength as well as leave a little more material due to the inside radius increase in the hone overtravel area.
Cheers.
From - http://www.corvetteactioncenter.com/..._pursuit1.html
The aluminum block, or "cylinder case", used in the LS9 is a relative of the unit used in the '08 Vette's LS3 and in the 6.2-liter, L92 GM puts in Cadillac Escalades and GMC Yukons, but it has some key differences.
First, there is a further strengthening of the main bearing webs by once again redesigning their windows. These windows allow the bay-to-bay breathing and oil windage control which helps lessen parasitic power loss and reduce crankcase oil windage.
GM Powertrain did a great deal of finite element analysis (FEA) work in search of a reliability/durability margin at the projected 620-hp similar to what the LS3 has with 430-hp. This research indicated that the windows in both the LS9 case's number-two and -four webs could be further strengthened by reshaping them in a manner that altered the stress concentration in each web. This reshaping, also, resulted in a slight increase in their areas. "Those windows are larger and have a non-symmetrical shape," Ron Meegan told the CAC. "When we made them larger, we were able to move the edge of the opening to a thicker portion of the bulkhead and that is where the strength improvement comes from. We were able to get to this sweet spot using finite element analysis. We incrementally increased the size of the window until we reached the maximum safety factor. If we go larger than this, the safety factor begins to decrease because the size of the hole overrides improvement from the increasing thickness of the bulkhead."
The window in #3, which, previously, was larger than those in the two and four webs, because the center web is the least stressed, was slightly reduced in area to match the profile and area of the other two. Testing proved that slight area decrease did not affect bay-to-bay breathing or crankcase windage.
The net result of this latest round of block window alterations was another, 18% increase in strength of the webs and a 36% increase, total, at the LS9's power level., beyond the first Gen 4 block, the LS2. This change is not specific to the LS9 and will be implemented for all V8 aluminum blocks starting in MY09.
Second, the main bearing caps are forged steel, like those those in the LS7, rather than sintered, powdered steel units in other Gen 3/4 engines, and they are aligned with dowel pins, another LS7/LS9 exclusive.
3) The crankcase is fitted with nozzles which aim an oil spray on the bottom of each piston for enhanced piston cooling and there is an interesting side benefit of them. "The oil squirters," Ron Meegan told the CAC, "are targeted to spray on the un-derside of the piston at TDC. As the piston moves up and down the bore, some of the oil gets deposited on the bore and the (acoustic insulating) effect of additional oil on the bore provides a noise benefit." These squirters screw into small passages drilled into the main bearing oil galley, 4) the block is threaded for larger, 12-mm head bolts and 5) it is bored and honed with deck plates bolted in place. Other aspects of the LS9 block carry over from the LS3, about which additional details can be found in the CAC's LS3 article.
Like all Gen 4 aluminum blocks, the units for the supercharged (SC) Small-Blocks are cast by Nemak in Monterey, Mexico, however, the LS9 case is finish-machined by Albert Weber GmbH. Initially the work was done in the company's plant in Germany, but that task is soon to be moved to its manufacturing facility in Charleston, South Carolina.
