LS2, New Heads, lost power? Ideas anyone?
The rockers were on in the original tune.. The ONLY thing that has changed since the original tune is the heads, LS7 lifters and clutch.. Nothing else has been done to the motor..
Why don't you look at the injector pulse widths from the run and compare the left and right bank. If they're the same, why no look at the fuel rail and see if something got messed up during the swap.
So I'm wondering if it's the valve seals that's causing the oil leak.. There is a fresh set of plugs in the motor now and I'm driving it over the weekend.. I'll be pulling the plugs on monday to see if they come out the same..
I'll be sure to post updated pix..
The plugs all looked like they were burning evenly and clean.
The leakdown test looked perfect, with cylinders registering less than 8 or 9 for loss. We checked valve seating, and air wasn't leaking around the valves either. Each cylinder was placed at TDC as per leakdown procedures.
Haven't done a compression test yet, but honestly the motor appears fine especially with such good results on the leakdown and the plugs burning evenly.
So:
Valvetrain was checked and is good (clearance, tolerance, PTV, geometry, etc--none of which should matter from what I've heard from several builders regarding these heads and the engine setup)
Leakdown is within spec
Plugs look good
.. So what next? Ideas? Try a different dyno just for kicks?
IMHO..
