LS2, New Heads, lost power? Ideas anyone?
Also my car doesn't run on the track.. It's been on the track once and that was when it was pretty much stock..
Anyone else have any ideas??
I really can't base how "strong the car feels" because I was gone for almost 3 months.. You tend to forget what your car feels like after being stuck on a ship for so long..
if you cant afford a fast buy a ls6 and have it ported. either one will shine over the ls2
my afr was right but my duty cycle was well over 100%
I guess one thing that I am looking for that I still haven't seen answered (or maybe I missed it) was in regards to the pushrods. How much pre-load is on them? My biggest concern is it's very rare for a stage 3 head to use the same length pushrod as a stock head. Also what procedure did you use when adjusting the rockers? I assume these are the bolt down non-adjustable type correct?
Also another problem that I would view is the oil. If there is oil in one bank (when it was on the dyno) it could be effecting the power. Now you said that the tests were done at sepereate times. Did you have these oil issues when it was dyno'd the first time? I know you said the plugs were clean this time, but there obviously was/is a problem causing the oil to appear at times.
The rockers are the non-adjustable just tighten down type.. Yella Terra..
I will get back with you about the preload tho..
Wouldn't preload have been evident on the leakdown test we did?
Basically here's the way it works... Not enough preload and you could potentially not open the valve all the way, but usually it would just have very noisy lifters and could run therisk of the pushrod dislocating itself. Now if it were too much preload you could see a power loss.
I always recommend 1 full turn, to 1 1/2 turns of preload, but 1 1/4 is perfect from what I have seen...
Regarding stock intake, you wouldn't have a power loss on the heads, worst-case scenario it would have to be something not the intake and you would simply not gain. Plus there's plenty of LS2 gto's with significant gains using a stock intake and aftermarket bolt-on heads. It could quite possibly be pre-load, let's hope it's simple like that.
I concur that the dyno was probably skewed with that oil, and should be done again. Will check pre-load first. We're very thankful Livernois is on the thread and is being constructive and very helpful, and we look forward to posting up our results either way.
