Head Gasket for LS2 Build
I'm planning on going to an LS2 Block when the time comes to re-build my Engine and I was thinking about a few things..
I already found the Extentions and things like that for the Knock Sensors and the Cam Sensor.
It's going to be a 10.85:1, NA Engine, no N20.
I was planning on using a Felpro 1041 Head Gasket, I've had good luck with these with my current build. This Gasket has a 4.135" Ring Bore, will that affect the Block at all? I see that Ring covering more of the Aluminum around the Steel Sleve than the Sleeve itself.
What are your guy's opinion..?
