LQ9 vs. LQ4- Block Only
Old Nov 3, 2008 | 08:20 AM
dankl's Avatar
Default LQ9 vs. LQ4- Block Only
Hey guys,
Used search, came up with a lot of good information. Just want to make sure the LQ9 and the LQ4 are the same exact BLOCK. Not talking about the pistons, heads, or compression between the two. Just need a 6.0L Iron Block. Are these exactly the same when talking about just the block?
Thanks,
Matt
Old Nov 3, 2008 | 02:43 PM
sroach20's Avatar
exact same.
Old Nov 3, 2008 | 02:57 PM
dankl's Avatar
Thanks, that is what I always thought. Just wanted to make sure.
Old Nov 3, 2008 | 03:19 PM
Big Bird WS6's Avatar
but 2000-2003 is different then 2004+
Old Nov 3, 2008 | 03:25 PM
the_merv's Avatar
Veteran: Air Force
The early ones have something different with the Oil Passages, I've read that somewhere..
Old Nov 3, 2008 | 04:57 PM
Vndcatr's Avatar
Is there a way to tell this difference ? And whats different in the heads between LQ4 &LQ9. I thought they both had 317 heads.. :-/
Old Nov 3, 2008 | 05:52 PM
sroach20's Avatar
the difference in years has to do with the head bolts.
Old Nov 3, 2008 | 07:57 PM
Hi-Po's Avatar
LQ4 here. Love it.
Old Nov 3, 2008 | 08:02 PM
TopFlite's Avatar
Very nice to see the LQ4/9 block revealing itself to be a reliable substitution for the LS1 in all type's of application's.
Old Nov 4, 2008 | 07:20 PM
GMCtrk's Avatar
The blocks are all the same. Both have the same 317 heads (99-00 LQ4 had iron heads and a longer crank to accomodate the 4l80e). LQ9 has beefier con rods and flat top pistons for 10.1:1 compression to the 9:4:1 of the LQ4. In 2005, both the LQ9 and LQ4 got the same con rods as the LS2. So, speaking on value, the ideal is to get an 05+ LQ4 since it has the stronger internals but is generally at least $500 cheaper than an LQ9.
Old Nov 5, 2008 | 09:22 PM
Sideways240sx's Avatar
This is all true. But hes asking block only. Could also get into longer crank, but wont matter cause its block only.
Chris
Old Nov 5, 2008 | 10:39 PM
Hi-Po's Avatar
Chris
Did not know that. 05 LQ4 here. Good to know, Im always looking for info on these engines here and looking for what others have done.
