Finally started up my 402 today!
Old Nov 17, 2008 | 07:34 PM
DrkPhx's Avatar
Only 15 miles? Come on, you built it to drive right?
Stay away from long extended highway drives at steady speeds. Stick to start and stop driving where the load on the engine is greater, constantly checking for leaks or unusual noises.
Old Nov 17, 2008 | 10:50 PM
LSGunZ28's Avatar
well Im unsire of my air fuel ratios, thats why Im not driving too much on it yet...
so far Ive seen no leaks, oil pressure is constant and slightly over 50 at cold start and above 40 at full warm up...
I have a couple of noises one sounds like I have a slight exh leak, but didnt spot any, so It may just be the sound of the car, because at cruise I dont hear it...
Also something is banging on the underside of my car or sounds like that, maybe the exh hitting my crossmmember... But I dont think anything unusual from my engine...
Old Nov 17, 2008 | 11:19 PM
DrkPhx's Avatar
Sounds like the Y-pipe is hitting the floorpan. Has the car been tuned yet? Do you have a datalogger?
Old Nov 17, 2008 | 11:44 PM
Fifedogg's Avatar
I had some of the exact same problems when I got my motor put in lol. Had the wires crossed and my Y-pipe was hitting
Old Nov 18, 2008 | 02:16 PM
LSGunZ28's Avatar
But my Y pipe wasnt hitting when I had the same exh setup before....
Old Nov 18, 2008 | 02:17 PM
LSGunZ28's Avatar
car has NOT been tuned yet... Idk what a datalogger is , but im guessing no...
my buddy with his HP tuners will check it tomorrow... so that Ill know its safe to drive... Ill get it tuned sometime next week(if they ever call me back from RPM)
Old Nov 18, 2008 | 02:45 PM
WADDISME's Avatar
"I have a couple of noises one sounds like I have a slight exh leak, but didnt spot any, so It may just be the sound of the car, because at cruise I dont hear it..."
I have that also. It sounds like exh leak, but I have tightened everything up as tight as it will go. Must be new motor?
Old Nov 18, 2008 | 07:47 PM
DrkPhx's Avatar
Good to know. Get it tuned asap. Datalogger is just a scan tool. HPTuners has a scan tool so I'm sure your friend will scan it.
Old Nov 19, 2008 | 01:10 AM
Fifedogg's Avatar
Neither was mine
Old Nov 19, 2008 | 07:49 PM
LSGunZ28's Avatar
UPDATE::
I changed my oil today.... and saw a lot of metal on the magnet which im sure is normal...
We welded a 02 bung to the exh today at a 2 oclock angle to the Y pipe after the o2 sensor.... and then we drove it today... We kept hearing detonation at 3500rpms and higher at WOT... We had the wideband connected to it...
the Air fuel ratio at WOT was between 12.8 and 13.1.... which was good... at cruise I was at 14.7ish and at idle it looked a bit lean, but I dunno how idle is supposed to look (also it wasnt fully warmed up) but I was seeing numbers of 15:1 and even 16:1 at idle (not fully warmed up)
anyways, Im at work and am hurrying up to type fast so my boss wont see this
(my comp isnt working at home)
is my car safe to drive still if Im getting these detonation at WOT above 3500rpms??
I also had a passenger with me... when I drove it home after I went to 4000rpms at WOT in 2nd or 3rd gear and I didnt get the detonation that time...
Old Nov 19, 2008 | 08:13 PM
Patrick G's Avatar
LS1 Tech Administrator
Check your PCV system. Oil mist getting into the intake manifold will make your engine rattle. A catch can is your friend here.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Nov 19, 2008 | 08:36 PM
  #32
LSGunZ28's Avatar
I actually got my catch can from Rev xtreme, in my mail yesterday, I still havent installed it...
BTW untuned, I can still tell I really like this cam already... Thanks!
Old Nov 20, 2008 | 01:23 AM
  #33
Haans249's Avatar
How much knock-retard were you seeing? What sort of timing were you seeing? What were your IAC steps at idle? What is your idle rpm hoovering around? What were the O2's doing, as in what were your LTFT's?
Old Nov 20, 2008 | 12:03 PM
  #34
LSGunZ28's Avatar
All I can tell you at this point is.... My idle rpm is about 950RPMs and pretty steady
Old Nov 25, 2008 | 12:31 AM
  #35
LSGunZ28's Avatar
I ordered my intake manifold today... FAST 92, with a PTM 95mm... I got this because I may port my own FAST 92....
Would my SLP lid work with this?? Also is a stock MAF gonna restrict me? I have a 85mm one as well, but am unsure whether I should use it or not (the car now is supposedly running on a speed density tune)....
Im scheduled to get dynoed on Dec 3 at RPM....
Lastly, can I install my int manifold and 36# injectors ... n My buddy has HP tuners, can I recalibrate them? or is this a bad idea?? any ideas on how to do so also, would be appreciated.. thanks
Old Nov 25, 2008 | 01:08 AM
  #36
Haans249's Avatar
Ditch the MAF if you're already SD, although then your lid will be the restriction in your intake tract.
You can install the int manifold and 36# injectors. Just make sure that your buddy knows how to properly scale the injectors, and you should be fine. But given the fact that you're already seeing KR, i would hold driving until you can actually get it tuned. Running lean can be just as damaging to a new motor as running too rich. Toss that int on, and you may push it too lean fyi.
