Finally started up my 402 today!
Old Nov 7, 2008 | 07:55 PM
LSGunZ28's Avatar
Default Finally started up my 402 today!
I finally started up my 402 today, after my buddy helped me, and plugged in all my sensors and extensions, etc... We primed the engine and fired it up!
It took a while to fire up , but it did!! (It must have been the older 91 octane gas winter blend?? or that it was very old, etc...)
It fired up, idled rough , but very steady, it was just the new cam in there... oil pressure was right at near 55 or so, went down to 48/50 after warmed up....
I have a few issues though like a leak for coolant, but this was when the car was off and it was overfilled, after the car was on it didnt leak... I just let it idle til it fully warmed up , then turned it off as my cooling cycle..
I Will NOT change my oil til I drive it 20 or so miles...
Also Im hearing a banging sound, but it sounds like its near the middle of teh car, maybe a trans mount or heat shield...
Lastly,my tach isnt working ...
Old Nov 7, 2008 | 08:01 PM
Patrick G's Avatar
LS1 Tech Administrator
Cool. It's been a long time coming. Keep us posted!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Nov 7, 2008 | 09:54 PM
DrkPhx's Avatar
Congrats! Sounds like the cam sensor harness wires need to be swapped.
Old Nov 8, 2008 | 12:19 AM
LSGunZ28's Avatar
Thanks, Ill check into that!
I think Im running too thick of an oil
3 qts 20 50 VR1, 2.75qts 15 40 rotellaT, .1 qt of random oil 5 30 non synthetic, when I first put in the lifters and rockers and a bottle of STP oil additive, which also is very thick..
so thats why Im seeing 50psi of oil pressure, vs when I used to see right at 40 at idle..
Old Nov 9, 2008 | 03:19 AM
Blkdoutbird's Avatar
Just curious but why would you use 3 different types of oil? Were you that impatient to fire it up?
Old Nov 9, 2008 | 05:03 PM
LSGunZ28's Avatar
No, I had some small amount of oil when I put in lifters and I poursed some over moving parts of he valvetrain to lubricate it, then I used a mix of Rotella T and VR1, since when I bought the Rotella T I was unsure if it had high zinc in it... but I already had poured some rotella T in the engine, before...
thats about what I have in there, right now..
Old Nov 10, 2008 | 09:25 AM
WADDISME's Avatar
The Rotella was on my list from TSP of acceptable breakin oils for my 402. For my 500 mi change, I switched to the VR1 20W-50 with the STP additive (overkill maybe). My oil pressure is like 65 at start up and falls to ~55psi when warm. They also had me do 2 45 min runs at varying rpms, then change oil before driving. That was a little bit of a pain. I will hit the dyno next week hopefully. Good luck with yours.
Old Nov 10, 2008 | 11:17 AM
Haans249's Avatar
When you actually are able to get on it and do a couple WOT runs to redline, that 50psi will probably drop down to around 45 because the oil will get much hotter than if it were to just sit there and idle or even casual cruising around. I wouldn't worry about 50psi warm, the oil is not HOT yet, and that is where you really want your protection the highest. Also, if your rpms are higher then before at idle, that'll also bump your oil pressure slightly. Everything is looking good!
Old Nov 10, 2008 | 01:56 PM
LSGunZ28's Avatar
Im not gonna pass 4000rpm at WOT, because of my stock injectors still, when I tune it soon, hopefully end of this week and recalibrate the 36# injectors, then Ill do so....
Im gonna go various rpms with high load and then engine brake..
instead of normall being at 30mph in 2nd gear ill be in 3rd andget on it, to case more load for the piston rings to expand..
Old Nov 10, 2008 | 07:08 PM
LSGunZ28's Avatar
Drove the car around the block today... had severe bucking and in need of a tune...
reasons, old gas in the car.... but I went and put in some new 91 octane
MAF was plugged in, even though it had a speed density tune(maybe it shouldnt matter, if MAF isnt working-im unsure if it is at this point)
exhaust leak, I think from between the header collector and Y pipe
cam position sensor wires may be crossed...
we pulled out a spark plug and theyre already fouled after a few miles. So its excessively rich...
what Im gonna do is:
tow the car to my friends shop and
Im gonna use the high temp orange silicone to seal the exh leak
Im gonna fix my Camshaft position sensor and see if I get my tach working
im gonna start and see if it runs better...
then Im gonna tow it to the tuner, maybe change the spark plugs there and just break it in on the dyno...
LSGunZ28's Avatar
http://www.mototuneusa.com/break_in_secrets.htm
Old Nov 10, 2008 | 07:17 PM
DrkPhx's Avatar
Fouled with gas? I would be careful with driving it until it's tuned properly. Definitely datalog to see exactly what's going on.
Old Nov 11, 2008 | 12:09 AM
LSGunZ28's Avatar
excessively rich..
Im getting it towed, I wont drive it...
Old Nov 11, 2008 | 01:13 AM
Haans249's Avatar
Pretty strange that it is running excessively rich being that its a larger motor. You're sure about your tune? I would do what you're doing, and not drive it, smart move.
Old Nov 11, 2008 | 01:53 PM
LSGunZ28's Avatar
the tune for this car was originally set for a 231/234cam (Tv3) in a 346 LS1... with 862 heads @ 10.75:1 CR .. now it has the same heads, but more compression(11:1 or 11.1:1), with a 238 244 cam and a 402 LS2...
I dunno who it was running rich, but it wasnt getting a good burn and the plugs had carbon on the electrodes...
exh leak, tricking the o2 sensors, bad gas, previous tune terrible for this settup? CKP wires crossed backwards? whatever it was, thats how the plugs came out...
Old Nov 12, 2008 | 08:18 PM
LSGunZ28's Avatar
So today a good friend of mine, fixed my exh leak as well as recrossed the cam position sensor wires and now i have a tach!!
also we pulled out the spark plugs and one side looked excessively rich and the other with a good burn, so we figured if the even side bank (passenger side) wasnt getting any spark, and surely enough thats why it was running shitty...
the connector was loose on the pass side and we reconnected it and it felt like it idled better as well as it was more responsive when we gave a quick blip on the throttle...
I let it fully warm up and we test drove it again... felt muccchhh better and responsive, as well as i felt good torque....
I drove around in 2nd and 3rd gear mostly and went WOT til 4000rpms and no more and let the engine brake down... I did this numerous times and we parked he car and a bit later I finally got to drive it home!!
Im very happy and will get it tuned very soon!!!...
Old Nov 12, 2008 | 10:44 PM
rotary1307cc's Avatar
hopefully you don't have a problem getting that bank seated in........ that was definitely not a good situation for the rings on that passenger bank
Old Nov 12, 2008 | 11:29 PM
Haans249's Avatar
Awesome! I bet you're super excited =D
Old Nov 12, 2008 | 11:39 PM
LSGunZ28's Avatar
I probably drove it 2 - 3 miles like that...
Old Nov 17, 2008 | 07:23 PM
LSGunZ28's Avatar
Drove my 402 some more today.... Feels nice... I checked my oil and Im gonna change it soon, Im seeing small deposits in it already... Im unsure, but Ive put under 15 miles on it as of now...
I keep giving it bursts anywhere from 1500-2000rpms and going WOT to 4000 and engine braking... Mostly in 2nd and 3rd gears... 1 or 2 times in 4th...
is there any other break in method I should be following?
