The secret of camming a L92 headed car.......
Don't trust the big names...... go with conventional wisdom.
My car kept loosing signal at 5200/5300 rpm and backfiring.... replaced the pcm, crank trigger, cam signal trigger, wiring, and a few other things..... as well as changed the cam while the shop was at it.
car picked up 5rwtq and over 23rwhp after the tq and hp curve crossed.
Previous cam from Synergy Motorsports: 236/236 made 455rwhp
New cam from Real Performance Motorsports: 236/248 made 478rwhp
Graph to come soon...
My advice is make damn sure you have a nice split... I am also sure it will work better on the bottle now too! 6.0's in the 8th here I come!
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
You did a lot more than just change the cam. How do you know it was the cam that caused the increase in hp and tq?
No tricks..this was an improvement from cam selection alone.
![Ripped](https://ls1tech.com/forums/images/smilies3/ripped.gif)
LS1Tech Premium Sponsor
What other changes did you make??
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
nothing.... wheels where lighter on the 455 pull with the 236/236 Synergy cam....
wheels where heavier on the 47X pull ( i don't have the graph in front and forgot the X number) with the 236/248 RPM cam.
All the mechanical problems started happening when I went down the track on the bottle and I thought it was a backfire... nope.. it was the signal problem. It plagued me for awhile... I thought it was the battery hitting the AC dryer and the car cutting out. It only seemed to do it at WOT. It was not an issue on the dyno after the 236/236 cam install.
Hindsight now says why recommend a square cam? It is easy to say that now... but conventional wisdom months ago would have said the same thing... I know Synergy wouldnt give me the specs over the phone on what he was recommending, but I was shocked just a bit when I saw the cam card.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Here is an overlay of one of the pulls vs the old cam....
Didnt fish thru to match the two best pulls... just random avg numbers here.... again..no tricks!
![](http://i24.photobucket.com/albums/c15/forteen3gt/RPM236-248DynoGraphvs236-236cam.jpg)
Matt, I forgot... we did change converters... from a lighter Neil Chance to the Vigilante converter for the TH400...... doubt that made a difference if anything it hurt the numbers.
So the power was virtually identical up to 5500rpm, and then has a funny jump about 5600rpm (not as smooth, starts climbing quickly instead of a steady climb you normally see.)? Can we all agree that's what we're seeing? What timing were you all seeing on the old setup from 5500+ rpm and what is it now? A/F in the same range before and after?
I'm not questioning the gains, they are clearly there. And I'd expect to pick up some power at the very top end of the graph from a big split, it happens all the time even on small cubed cathedral port headed cars. I am just trying to clear up some possibilities that could account for some of that power.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
LOL! For some off reason, people do that all the time! Crazy IMO!
__________________
I'm not questioning the gains, they are clearly there. And I'd expect to pick up some power at the very top end of the graph from a big split, it happens all the time even on small cubed cathedral port headed cars. I am just trying to clear up some possibilities that could account for some of that power.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Mechanically everything is the same.... both times the plugs were new. I do have a different maf since the old one blew up on us... Dyno is a drive-on lift DynoJet.
As far as specs..... I don't recommend buying something without knowing what you are getting for this very reason. I trusted that Rick at Synergy had a knack for this L92 stuff... this comparison proves that to be incorrect and I would have been better off with the 236/248 cam from the get go. Driveability and idle have not been compromised and I will make more power with the bottle now. WIN WIN here. What else can be said? He shipped me the cam specs based on the info I shared with him... and the local shops cam made significantly more power on my L92 headed car.....
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
Mine was spec'd at a 243/247, 114+3 LSA by a person also known on here to spec some good Cams.
Shifting at 6500RPM it ran 7.1's in the 1/8th, 11.19 in the 1/4 N/A, 32* Timing, running a little rich too..that was with the old Auto setup, the new M6 setup is more for street use..not setup for the 1/4 mile that much really. Stall was a Yank SS3600.
I'm running 238/242 605/615 113.
Haha, this is his most retarded thread to date. He changed the cam, converter, MAF and fixed a signal problem by replacing a bunch of stuff. You could have lost power from the cam and gained enough from the other things to show the same results. That's not necessarily the case, but you can't rule it out.
So you replaced the pcm, crank trigger, cam signal trigger, wiring, torque converter and cam....
And you are putting the gains just down to the cam? Right?
Which made identical power and torque to 5500rpm
Let me guess, you put a more efficient converter in it didn't you?
![Punch](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_punch.gif)
