4" bore block with ls1 style heads
Old Nov 19, 2008 | 08:26 PM
turbogarrett's Avatar
Default 4" bore block with ls1 style heads
I have a pair of 60cc, tfs "as cast" heads designed for an ls1. Would I run into any problems using a stock LS2 or L92 shortblock? Would the chambers have to be enlarged? This probably has been covered before, must not not be searching with the perfect combo of words TIA-Garrett
Old Nov 19, 2008 | 08:30 PM
ChucksZ06's Avatar
You could open up the sides a little. Will help unshroud valve and get you a little more flow. You will reduce your compression a little with the larger chamber.
Old Nov 23, 2008 | 09:13 PM
TJ's Avatar
TJ
im running a 3.90 bore head on a 6.0 with no issues.
it does shroud the valve a lil, but i got a deal on them.
