snapped a timing chain again
Old Nov 22, 2008 | 10:17 AM
tinker-27's Avatar
Default snapped a timing chain again
as the title says i have a stroked ls2 motor and it snapped a duplex chain after about 5000 miles and we were told it helped to use a timing chain damper (v shape thing in the middle off the chain,so we rebuilt the motor all new bits comp cams chain kit (single row chain) with damper. the motor runs very well but stopped again and the new chain has snapped again !! it looks like a bad chain but could i be that unlucky or is there something else i am missing , it all run in line and the cam runs free. there is no evidense off any out off line problems it just snapped clean through a link.is a genuine gm chain the best as all our other motors are ok ? any ideas ?????? cheers craig
Old Nov 22, 2008 | 10:41 AM
socmguy's Avatar
Restricted User
Has there been and PTV contact? I've seen that break off Cam dowels. Could also break the chain.
Old Nov 22, 2008 | 11:46 AM
DrkPhx's Avatar
Sorry to hear of the misfortune. So you broke two differerent brands of chains? Did it happen under similar operating conditions (i.e. WOT, deceleration, just cruising)? I would also guess a bad chain, but it's really hard to say. How is the rest of the motor?
FWIW - I have run the same GM LS2 timing chain and damper on two different motors for several thousand miles without a problem. Car is shifted at 7000-7200 rpms.
Old Nov 22, 2008 | 12:05 PM
the_merv's Avatar
Veteran: Air Force
What RPM's are you spinning at?
Old Nov 22, 2008 | 02:00 PM
ss1's Avatar
ss1
Sounds like more than just bad luck to me. The GM LS2 chain is suppose to be the way to go...
Old Nov 22, 2008 | 02:19 PM
427's Avatar
427
I think you should change your crank dampner. Are you road racing the engine? Do you spend much time at full throttle between 3800-4400 rpm?
Kurt
Old Nov 22, 2008 | 03:29 PM
BlackScreaminMachine's Avatar
Internet Mechanic
A lil too much coincidence.....
Old Nov 22, 2008 | 03:32 PM
03 BUSA's Avatar
I agree something is not right.
Old Nov 22, 2008 | 07:06 PM
scooter k's Avatar
I've seen the LS2 chain break in a TBSS. Snapped the chain when he was on the throttle hard backed off and back on. Bent all the valves and did alot of piston damage. Thought the RPM was around 4500 when it broke. Never could find anything wrong and why it broke. It did have a underdrive pulley on it at that time. We went with a Katech timing chain. I haven't heard of anyone breaking a Katech chain. It will run you about 140 dollars and runs on the stock gears.
Old Nov 23, 2008 | 12:38 AM
the_merv's Avatar
Veteran: Air Force
The LS2's are supposed to be pretty stout.. I guess everything has it's limits..
Old Nov 23, 2008 | 08:20 AM
vettenuts's Avatar
Something else appears to be wrong, the chain is likely the symptom but not the cause. Are the gears in alignment? How much end play on the cam?
Old Nov 23, 2008 | 09:16 AM
tinker-27's Avatar
it is a race car and both time it went into a corner on part throttle ,just a bit off slack as you would expect,it has a spi ? front underdrive on it, it does spend a lot off time between 300-5500 and rev limit set to 7000 ( all steel motor).and it is a different cam from last time all in line, it just looks like a clean break the two halves off the pin are still in the side plates . seems like two much for bad look !!!!
Old Nov 23, 2008 | 09:18 AM
the_merv's Avatar
Veteran: Air Force
Too heavy of Springs?
Old Nov 23, 2008 | 09:32 AM
veee8's Avatar
Harmonics......
Old Nov 23, 2008 | 09:45 AM
the_merv's Avatar
Veteran: Air Force
Yea..something is off balance to cause that..or loose..
Old Nov 23, 2008 | 01:53 PM
tinker-27's Avatar
it had RHS heads on the first time and a 238 cam now 250cam and trick flow heads with 218 springs, there is no sign off wear at all the first one lasted 3-4000 miles the second 500 miles !! i does look like a faulty chain but would like to be sure ,
Old Nov 23, 2008 | 08:13 PM
Grimes's Avatar
One chain may be bad luck, but a second one so soon is signs of another problem that caused it....
Old Nov 23, 2008 | 08:49 PM
craze4speed's Avatar
you need to check the end play on the crank! i think you will probably find your problem, you should not have broken two timing chains, theres something wrong that!
Old Nov 23, 2008 | 09:05 PM
TJ's Avatar
TJ
what i was thinking.
crank could be walking just enough to put things in a bind.
odd to bust 2 chains so soon.
Old Nov 23, 2008 | 09:18 PM
yeah i see your in pcola not too far from me, you ever come over to mobile?
By Brett Foote | 2026-06-04 05:00:17
