402 compression question
Old Nov 26, 2008 | 09:52 PM
scites's Avatar
Default 402 compression question
ok i bought my 402 from a guy that had it built by HKE and he lost the build sheet, but the ross pistons that are in there are like -8cc pistons. what would my compression ratio be ruffly with a 64cc head..if i need to measure anything else let me know and i will
Old Nov 26, 2008 | 10:16 PM
LLC's Avatar
LLC
Not enough information.
Zero deck? Out by .005 or more?...........in by .010? Need to know the deck.
What thickness head gasket is being used?
"roughly"
Old Nov 26, 2008 | 10:29 PM
scites's Avatar
MLS i believe .051 i beleive on the head gasket. deck i believe is zero..id have to measure it ..
Old Nov 26, 2008 | 10:55 PM
carzmed's Avatar
http://www.c5frc.com/calculators/Com...Calculator.htm
Try to keep quench at .040 or .045
Old Nov 26, 2008 | 11:17 PM
scites's Avatar
thanks bro, that helped a lot..
Old Nov 27, 2008 | 10:45 AM
DrkPhx's Avatar
I like this calculator because it takes in consideration either a positive or negative deck height.
http://www.rbracing-rsr.com/compstaticcalc.html
BTW - HKE should still have the build sheet on file if it was a recent build. I would call HKE with the previous owners name and approximate purchase date to get the specs.
