Who has Hi-power L92 build-up?
Just wanted to know what you guys that are making 600 plus hp are running for compression and cam specs. I am researching a few L92 based builds with 6.0L iron blocks and L92 blocks as well. Please, do chime in if you have dyno proven combinations. Thanks
Check out this thread over on CF:
http://forums.corvetteforum.com/perf...plus-rwhp.html
Best I've seen yet from an L92/LS3 Stroker.
Jimbo
Jimbo
I have L92's with an LS7 block. (441ci)
Dyno #'s are a bit misleading because of the non lock-up trans but she made 536 rwhp and 636 rwtq on the dynojet. (hydraulic set up)
track times in the sig.
Jimbo
Jimbo
I know the guy, I've seen the Engine, and he spins it to 7K+ in that Dyno. It's got a wierd curve on that first pull..
This isn't a LS3 Headed Engine, so I post this assuming we are looking for good Cam/L92/LS3 Head Combos in here, unless it's everything L92/LS3.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I'm sure that anything over 400ci with a decent Cam and L92 Heads, even stock ones at a decent Compression Ratio should pull over 600 NA without a problem.
I figure mine to be around 600 at the Flywheel.
Specs:
Stock L76 Intake
L92 Heads Milled .025, ~66cc Chambers
10.7:1 Compression with Pistons and Felpro #1041 Head Gaskets
Cam: 243/247, .621/.612, 114+3 LSA
It pulls hard to 6500RPM, that's where it drops.
Specs:
Stock L76 Intake
This guy did a lot of work on the L92 setups a while ago. Lots of good info and his car is over 600 at the crank and drives about like stock.
https://ls1tech.com/forums/generatio...us-plan-b.html
Specs:
Stock L76 Intake
Specs:
Stock L76 Intake
Do you think the drop at 6500 RPM is due to the intake manifold?
Jimbo
Jimbo
I am too Ed, I'm hoping to see 550 with mine once I get it back together.
Should be soon as the short block is on it's way back to me. (spun #2 rod bearing at 1700 miles). If I wind up with something over 550 rwhp I'll be VERY happy. The spikes on his dyno sheets really make me wonder WTF is going on.![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Jimbo
Jimbo
Does it do what you think it should do?
Are you satified with the results?
Do you have any close-split vs. wide-split ideas and or comments?
I'm just trying to put a nother L92 combo together with the BEST results that I can possibly get.
Thanks again to all who help/participate.
