402 rotating assembly questions
Old Nov 29, 2008 | 09:49 AM
DemonInside's Avatar
Default 402 rotating assembly questions
ok SCPC is running a sale on rotating assemblys and i wanna ****** one up before it ends
im looking at this one
http://www.sdparts.com/product/LS2RA...gAssembly.aspx
-2 pistons with 11:1 with 70 cc chambers
couple questions i have are,
- should i order more of a dish piston and get my afr 225's milled so the combustion chambers are smaller? not sure if haveing the same compession with a smaller chamber is any better then with a big chamber
-i want it pump gas safe, im told 11.5:1 is as safe as it can get for 93 octane, how many cc's would my heads have to be with this combo?
-i was going to order l92 gaskets (4.065) or will the ls2's be fine and not hang off into the bore? any one against useing a stock gm multi layered gasket?
-i plan on haveing a pretty decent sized cam in it as well, would i have any issues with such a small dish for ptv clearence?
-lastly if i ever decided to supercharge it would the Manley forged Pistons and
Ackerly & Childs Moly Rings be alright ?
Old Nov 29, 2008 | 10:49 AM
DrkPhx's Avatar
You should be good with 2cc valve reliefs. My AFR 225's are milled from 72cc to a 66cc chamber. However, be careful about milling too much. Tony from AFR did the work including addition port work.
Depends on the deck height and head gasket. I run Wiseco flat tops with 2cc valve reliefs with a calculated 11.8 static compression on pump gas.
You have to use a 4.130 minimum bore diameter head gasket when using the AFR 225 cylinder head. I use .045 Cometics.
Piston to Valve clearance depends on a number of factors. You have to measure for ptv clearance of your actual setup to ensure there is no contact.
-lastly if i ever decided to supercharge it would the Manley forged Pistons and Ackerly & Childs Moly Rings be alright?
I would contact a shop with experience with those rings in that type of setup. There are quite a few sponsors, maybe give them a call.
Old Nov 29, 2008 | 02:24 PM
well not trying to be cheap but why not just use the ls7 head gaskets
since they have a 4.130 and .051
save a few bucks if these will do what i need for the time being and when/if the time comes i want to supercharge it ill swap out the gaskets and put in arp head studs as well
Old Nov 29, 2008 | 02:54 PM
Disturbed Bird's Avatar
alot of guys including my self run the gm multi layered gaskets they go by the name of mls gaskets if you didnt know. i think they are good and hold up great. i also use the -14cc manley pistons that Scoggin put in my 402
Old Nov 30, 2008 | 01:43 AM
ok ive done some reading, im thinking the -2 cc pistons will be fine for what i want, but i have been reading about quench so im thinking i need a tighter quench to reduce pinging changes. so i was gonna use those pistons some Cometic head gaskets to try and get around .035 quench instead of a .041ish with the ls7 gaskets, figureing if my piston sticks out the hole .010ish, my last 408 stuck out around that so im kinda figureing it to be simular.
-2cc pistons 68 cc heads .045 gasket factor .010 out the hole for a quench of .035 and a compression around 11.6:1
sound about right to you guys? or am i wrong about qhat i read about quench and shouldnt worry?
sorry for the prolly dumb questions im just trying to get this motor dead on this time!
Old Nov 30, 2008 | 10:36 AM
novaflash2002's Avatar
Not doggin on sdparts, but call up texas speed, and they'll stand behind you for life.
Old Nov 30, 2008 | 09:00 PM
DrkPhx's Avatar
Sounds right. Here's a good calculator to double check. Tip: Don't buy the head gaskets until the short block is built so you know the exact deck height for your motor.
http://www.rbracing-rsr.com/compstaticcalc.html
Old Dec 1, 2008 | 09:28 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
We'll take care of him very well. Thanks
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Dec 1, 2008 | 10:05 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Thanks for the referral!
http://www.texas-speed.com/shop/item...d=885&catid=88
We have a 402 few rotating assemblies to offer as well at competitive prices. Let us know if we can help
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Dec 1, 2008 | 10:38 AM
Indeed you guys did thanks again, i ordered everythign i could until i put the motor together
Old Dec 1, 2008 | 11:02 AM
We appreciate it. If you need anything else or have questions, let us know and we'll help you out
__________________
