noob question
Old Dec 2, 2008 | 04:21 PM
Austin@HPE's Avatar
Default noob question
in a cam spec ex 232/236 605/610lift 112+2 what is the plus two?
Old Dec 2, 2008 | 04:23 PM
Austin@HPE's Avatar
is it advancing the cam if so what is the benifet?
Old Dec 2, 2008 | 10:38 PM
blackonblack02_Z's Avatar
Its two degree of timing ground into the cam. As for the benifit I will let someone else go into that explanation
Old Dec 2, 2008 | 11:02 PM
BillyBob750's Avatar
Yes, its degrees of advance ground into the cam. Most off the street cams will have a couple degrees ground in. You'll lose a little peak power, but you'll pickup power under the curve.
Check out the "Cam Guide" in the Gen III section. Offers a ton of helpful information.
Old Dec 2, 2008 | 11:11 PM
DemonInside's Avatar
i was curious on this as well, how is a cam like this degreed ?
