235 trickflow on 6.0 iron block?
also, is it possible to run tfs235 on the 346 for awhile until you do the swap.i know it would be prob not be a good fit, but it must be better than stock heads for the time being. i would hate to throw on another 3gs on top of the engine swap for the heads alone.
346 is way too small for the 235 heads. 215's are better suited for that application. Or 225's for now if you are planning on running with the 346 for now then going bigger later.
These are definitely bigger cam FAST 92 deals with good headers and everything obviously.
are we talking 600whp in a 6 spd 10 bolt car with all dyno tricks?
curious how large a cam id have to go with to make mad power with a 11.5 static compression 408
