LX CNC LS7 style manifold by Performance Induction
#145
Ok. im looking at this manifold or a ported super vic for a carb deal.
The as cast maniold i have been told needs work...to work. So what needs to be done to get this manifold to out do a ported super vic without going the cnc $2000 doller deal. So
Will the manifold work as Cast...?
Will it out do a super vic with port match only?
will it out do a super vic with hand porting?......cost?
#146
Last edited by LSmonster; 07-18-2010 at 08:40 PM. Reason: added "port match option."
#148
I can't say this for sure so you should call Cary but I didn't think the as cast was really usable in that state. It really needs a lot taken out it looked like, not just cleaned up. It was cast to be machined. Not cast like other production manifolds that can be used as is.
#149
#150
as cast will not work. The intake is designed to be ported not ran "as is". I recently purchased cary's intake as cast and realized once I recieved it that it has to be ported. I sent it back and cary is porting it out w/hand finish. The cheaper route would be to order with the bottom half ported. It is about half the cost of the full port polish version.
#152
#153
#156
#158
Can anyone tell me injectors that suit this manifold with the rails that are supplied. Are they the standard height, mid size or shorty injectors ?
And also who stocks the accufab TB that will send to australia ?
Thanks
Thanks
#159
the new accufab t/b (which has the bigger base then a dom 4500 tb) will need a spacer rail
if you get stuck and need some specs/pictures pm me as i am in Melbourne Australia
business, cnc, cylinder, etp, heads, induction, inductions, intakes, ls7, lx, manifolds, marcella, perfomance, performance, products, racing, specialties
