New Aftermarket Aluminum Block on the horizon
Old 12-11-2008, 02:57 PM
ReiKo's Avatar
Rumor has it the block is going to cost a little north of 5k...
Old 12-11-2008, 03:29 PM
1.8t's Avatar
^ Sheesh, thats pretty steep. Good thing I am never planning on making enough power to where I will need a warhawk or this one. 700~800whp on the factory available aluminum blocks will be no issue.
Old 12-11-2008, 05:59 PM
DrkPhx's Avatar
Is this the block mentioned in this thread?
https://ls1tech.com/forums/generatio...block-rhs.html
Old 12-11-2008, 06:10 PM
LS1Tech Sponsor
Robin L's Avatar
Yep.......
Robin
Old 12-11-2008, 07:57 PM
dkbykesdk's Avatar
High-strength A357 – T6
Standard & tall decks
Std 9.240” deck
Tall 9.750" deck
Designed for up to 4.6” stroke
Increase bay-to-bay breathing
Raised cam centerline: .386”/9.86mm, 2 chain links
Std .842 lifters, up to 1.060” lifters possible
6 head bolts
4.060 - 4.165” bores
Gen III / IV compliance
Serious dry sump provisions (built in AN-12 feeds)
Gen I / III / race mounts
Priority main oiling
Ampco 45 cam thrust plate
Rear cover included
Siamese cast bore walls
Press-in spun cast iron liner
4.060 to 4.165 bores
Water jacket based on LS7
Liner lengths:
Std deck: 144/149 mm (same as LS7)
Tall deck: 157/162 mm
Maximum pushrod angularity = less than 2deg
Bay-to-bay breathing improved with increase in window area:
Passage under bores:
Center bulkhead 4% area increase over LS7/LSX
Same window on all cylinders, so 39% increase on #2 and #4 over LS7/LSX
Passage around caps
7% Increase in area over LS7/LSX
All threads 'rolled'
Chilled mains
cast-in piston oil squirter provisions
Old 12-12-2008, 06:01 PM
horsepower's Avatar
jobber price is 4616, call for dealer pricing.
pics of the 'real' blocks:
Old 12-12-2008, 06:59 PM
LSX-PWR's Avatar
I guess my Christmas is going to have to come in April. I almost feel sorry for the Ford guys.
Old 12-12-2008, 07:01 PM
LSX-PWR's Avatar
Whats going to be the weight on these bad boys?
Old 12-12-2008, 08:30 PM
njc.corp's Avatar
so the knock sensors are back in the valley?
looks nice-
Old 12-14-2008, 12:24 AM
njc.corp's Avatar
seen the vid on street legal tv at the pri show
damm nice block-
Old 12-14-2008, 12:58 AM
Tom@SpeedInc's Avatar
looks nice-
Believe the knock sensor provisions are in GEN III and GEN IV locations
I don't see a cam sensor hole in the back of the block, but thats the least of my concerns. LS2 cover is pretty standard issue nowadays.
Old 12-14-2008, 01:40 AM
  #32
LS6427's Avatar
only capable of a 4.165 bore????????????
Old 12-14-2008, 06:36 AM
  #33
njc.corp's Avatar
Smile
Thanks fraser-
this should be good-
Old 12-14-2008, 08:39 AM
  #34
427
427's Avatar
The block was not machined, but the pad for LS1 cam sensor was back in the rear of the block. This is one of the top improvements for guys that want COP with a Jesel belt.
Kurt
Old 12-14-2008, 10:57 AM
  #35
horsepower's Avatar
Will have BOTH gen III (valley) and gen IV (side) knock sensor provisions
Will have gen III cam sensor provision, or you can use a gen IV front cover cam sensor (will require modified front cover, with raised sensor boss, will be available from RHS too)
can run with gen III or gen IV valley covers and oil pressure sensors
max bore is 4.165 (remember, aluminum block) and with a 4.6 stroke this equals 502 CID. 502 inches ought to be good for you.
Old 12-14-2008, 11:06 AM
  #36
DVS99TRANS's Avatar
Can still run LS7 heads with it with 4.165 bore. Provisions for oil squiters Damn, looks like I need to save more
Old 12-14-2008, 04:32 PM
  #37
njc.corp's Avatar
Question
dont see a reason why u cant run a ls7 head-
Old 12-14-2008, 07:46 PM
  #38
DVS99TRANS's Avatar
I was just stating that it had atleast the recommended bore to be able to use them that's all Take this block and turn it into a 502 LS9 type motor, hmmmmmmm. i also like the fact of possible lifter access through the valley instead of lifting the heads off. Might not enough room though, but might be possible...
Old 12-14-2008, 08:19 PM
  #39
njc.corp's Avatar
Question
can the normal deck take the jesel belt set-up and u guys making one for the tall deck or jesel will?
Old 12-14-2008, 09:31 PM
  #40
LS6427's Avatar
with the 4.165 bore, does that leave a ton of gasket still there between cylinders or is that the max bore and you'll be pushing it for boost or nitrous?
Quick Reply: New Aftermarket Aluminum Block on the horizon
