2000 5.3 swap to 2008 5.3 help
Old Dec 9, 2008 | 10:32 AM
59rat's Avatar
Default 2000 5.3 swap to 2008 5.3 help
I am picking up a 2008 5.3 & trans Saturday to put in my wife's 2000 Yukon. I am getting the computer and wires for the motor with it. Is this a simple plug and play or is there going to be surprises? Any help or advice is appreciated. Thanks Rod
Old Dec 9, 2008 | 07:53 PM
1quickirocz's Avatar
dont think its going to be so easy. 2008s use a different type of data communication between the modules. The 2000 uses the class 2 serial data communication system and the newer ones use the gm high and low speed LAN communication system. completely different from each other. I think you are going to have all kinds of body control problems. I think you can still make it work but its going to take some research and programming. probobly not plug and play tho
Old Dec 10, 2008 | 05:52 AM
59rat's Avatar
Thank you for the reply. Is there anyone that I can call to see about programing or wiring harness? Rod
Old Dec 10, 2008 | 08:06 AM
you might try any of the after market harness people. i dont know off the top of my head but im sure someone on here can lead u in the right direction on this. im sure someone has done this before.
Old Dec 11, 2008 | 09:58 AM
59rat's Avatar
OK here's one thing I found. Lingerfelter makes a computer that links the 24 tooth to the 58 tooth. Now with that said the guy could not tell me if that was all I needed.
Old Dec 12, 2008 | 05:37 PM
59rat's Avatar
I saw the part today at the PRI Show small box with 4 plugs cam in cam out, crank in crank out. SDPC had it in their booth.You also need an extension for the knock sensors, which they have. I know I'm talking to myself (LOL) but someone may need the infor. one day. Rod
Old Dec 25, 2008 | 08:26 AM
59rat's Avatar
FYI
Old Dec 26, 2008 | 06:46 PM
Bo185's Avatar
The cam is different as well the sensor is 4x vs 2x. Might have to swap the cam sensor as well or the cam.
