i need help
Old Dec 10, 2008 | 10:48 AM
nazztman4739's Avatar
Default i need help
can someone tell me what a 6.2 liter ls engine is worth out of a escalade low milesand will the heads off my ls1 work to boost the compression i want a quick replace while i build another engine is it a aluminum block or iron?
Old Dec 10, 2008 | 10:58 AM
1sick'98WS6's Avatar
I have seen them go for anywhere 3k-5k for one that is from a legit seller.
Keep in mind that you will have to get rid of the VVT by switching lifters, cam, and it will need a 24tooth if going in fbody plus other wiring modifications. It is aluminum
Old Dec 10, 2008 | 01:09 PM
thank you what kind of wiring changes and what is vvt? can u change the relucter without changing the crank? also could i use my cam and lifters out of my ls1
Old Dec 10, 2008 | 01:21 PM
1 more question could i use my ecm?
Old Dec 10, 2008 | 03:59 PM
If you want to use your pcm with that motor you will need to swap the variable valve timing cam, and lifters. But I wouldnt recommend using your stock ls1 cam with that much more displacement 5.7 to 6.2, youd want to move more air with larger lift cam. The lifters should be replaced with new also, not neccassary but a good idea
You will have to remove the crank to have the 24 reluctor ring fitted.( Machine shop put mine on for 40 bucks)
The only wiring changes would be the cam sensor harness will need an extention and knock sensor extention ( sdpc sells one that does both in the same harness)
Also you will need an l76 intake or something else because the newer heads on an l92 will not accommadate the ls1/ls6 style intake
Here is some backround on the L92 https://ls1tech.com/forums/generatio...-l92-info.html
Old Dec 10, 2008 | 05:33 PM
could i use the l92 intake? i have intake to oilpan
Old Dec 10, 2008 | 05:50 PM
by the way thank you for your insite i was kinda confused would i have to flash my ecm?
