.040 head gasket
Old Dec 15, 2008 | 10:14 AM
DemonInside's Avatar
Default .040 head gasket
i tried doing a search but not any luck, ok so im looking for a head gasket for a 402 4.005 bore motor im useing some tfs 225's
i was told cometics are very crucial on haveing everything machined perfect or they will leak so i was advised to go with a felpro
now what bore size gasket should i run ? i want it with a .040 compressed thickness
Old Dec 15, 2008 | 11:09 AM
405HP_Z06's Avatar
Fel Pro's are out of the question if you want .040 MLS gaskets because they don't make one. The only gasket they offer that's close is the 1041 which is a steel core laminate instead of MLS.
IN MY HUMBLE OPINION, the Fel Pro is a better gasket but Cometic offers more options and they are reliable if you prep the deck surfaces correctly.
I'm running the Fel Pro 1161's and have had no issue's over the last year of daily driving.
Old Dec 15, 2008 | 01:44 PM
the 1041 will work i just didnt want no .045-.050+ ya know
these will be ok for a daily driven (only on warm non rainy days) 402 with around 11.5:1 scr?
Old Dec 15, 2008 | 04:31 PM
405HP_Z06's Avatar
The 1041's are .041 crushed and have a 4.135" bore so they should work; also, confirm the width of the combustion chamber. From a reliability perspective, they are good gaskets so you should have no issues with what you want to do.
Old Dec 15, 2008 | 05:04 PM
cool thanks i wasnt sure if that'd be too big of a bore on the gasket but doubt it will be a issue, im gonna wait till im assemble my motor(3 weeks) to see how much the piston sticks out the hole before i order them, i just wanted to get a heads up well before then
Old Dec 15, 2008 | 05:48 PM
71CamaroLS1's Avatar
I've had Cometics on an LS1 (used) and LS3 (new) now with no issues at all, and no special prep done. They have far more options in terms of bore diameter and gasket thickness.
