LS3 Timing Chain Failure :(
On a side note I know of a particular '04 LS6 in a Corvette which has eaten two timing chains in a year.....the car is ran on roadcourses. The 04 LS6's were actually equipped with the "LS2" chain and he has broken them twice. He was lucky the first time and just kissed some of the valves, the 2nd time he wasn't as lucky and had to replace the long block. His engine was strange in the fact that it was a late '04 production vehicle and when we took it apart the first time the car was equipped with the "LS2" chain, but the engine block was drilled for the earlier design timing chain dampner. We put it all back together and all as fine and as stong as ever . Slightly over a year later ....another chain let go this time ventilating some pistons......
One thing I know these chains do NOT like is rapid/abrupt engine speed changes such as rev-limit too long , very abrupt hard upshifts, and downshifts in roadcourse applications without correct engine speed matching.
It is disheatening to see you have this problem with the new spring loaded timing chain tensioner.......I was looking forward to using the tensioner on my JWIS chain on my solid roller motor.
- 9-4194 - The single row chain currently packaged with timing sets:
- 9-3153A, 9-3158, and 9-3158A
- 9-194 - This is the heaviest duty single row chain Cloyes offers for the LSx engine. It is not in the current Cloyes catalog but still available in limited quantities. This is the chain the OP purchased in this thread and costs approximately $360 for chain ONLY. This chain originally came with timing set:
- 9-3153AL
You would need to determine what part number timing set you purchased to determine which chain you have. More than likely you have 9-4194.
The car *may* have kissed the rev limiter 5 times in the 15k miles I have driven it. I was aware of TC issues well before mine broke and thought I took the appropriate measures to ensure I had no issues. I rarely rev match on the street and always selected a higher gear as opposed to a lower one to prevent the rpm rise associated with using the lower gear. As for abrupt upshifts, I am definitely guilty of that at the track. However, my street shifts were very docile to prevent any accessive abuse to the tranny or clutch.
It seems that the severe stress on the chain comes from the crank/flywheel rather than the belt side?
I was told by some of the involved manufacturers that it is more of a harmonic vibration issue made worse by lighter smaller diameter dampers which make your comments interesting.
Crank twist IS the harmonic vibration and that's why I said a bigger damper is generally better.
