LS3 Timing Chain Failure :(
Old Dec 24, 2008 | 10:13 AM
  #121
1.8t's Avatar
DrkPhx, I have a ton of bent valves.
Old Dec 24, 2008 | 02:31 PM
  #122
Rob 's 73's Avatar
my second break did look like yours. Replace all valves that left ANY witness mark on the piston. First time I bent 9 and second time 10. Inspect your valve guides. The second time I crack two guides. Heads now have all new guides and valve job. Plus some Mamo magic applied to them. I'm convinced mine was from the lack of TC damper, ASP pulley and road racing.
Old Dec 24, 2008 | 02:56 PM
  #123
1.8t's Avatar
All valves will be replaced and the heads will be sent off to a machine shop to be gone though. Everything will be done right, the only shortcut I am taking is replacing the bottom end.
Old Dec 24, 2008 | 03:40 PM
  #124
camarorat's Avatar
Ok, i have lost track of this thread. I know you were running NA car with bolt, and TC damper. Where you running aftermarket Balancer, timing chain? If so what were you running? This is making me very nervous since I am in the midst of building my 402 stroker. I wans't even thinking about balancer? should I go with double (what brand) or single ?
Old Dec 24, 2008 | 04:02 PM
  #125
1.8t's Avatar
I was running the stock chain and an ASP underdrive pulley. I would definitely go with a quality double roller if that is available. Cloyes seems to make some of the best timing sets/chains from my research.
Old Dec 26, 2008 | 03:50 PM
  #126
camarorat's Avatar
I have been reading alot of threads on this subject over the last few days, and I have to say that a large majority of the timng chain problems have been on cars with aftermarket crank dampers. Anyone have, or hear of such problems with stock or ATI?
Old Dec 26, 2008 | 06:25 PM
  #127
405HP_Z06's Avatar
I know the stock damper will fall apart under severe driving conditions. I'm not aware of any failures with the ATI, but that doesn't mean it hasn't happened.
Old Jan 2, 2009 | 02:07 PM
  #128
1.8t's Avatar
Bit more of an update. Finally got my Crane Cams valve spring compressor tool for the L92 heads(great tool btw) and got both heads broken down. I have now have some concerns.
When I was first tearing everything down, I found the piece of material pictured below on top of my #5 intake valve. Thinking it was guide material, I continued on with the tear down without much thought. However, after getting the valves out today, the guide looks perfect on my #5 port. That being the case, does anyone have any idea wtf this is?? All I know is it is some kind of non-magnetic alloy and it was found on top of cyl. #5's intake valve.
Pics:
On another note....edited because I was wrong...
Old Jan 2, 2009 | 02:23 PM
  #129
405HP_Z06's Avatar
Pics:
<snipped>
On another note, I got my cloyes timing chain and although I know the differences can't be seen, it was a little disconcerning that it looked identical and felt identical to my stock chain. Guess we will see how tough it is once everything goes back together.
Looking at the picture vettenuts posted earlier in this thread, there should be a visual difference between the Cloyes IRL and the stock chain. I would call Cloyes and make sure they didn't ship the wrong chain:
Old Jan 2, 2009 | 02:28 PM
  #130
1.8t's Avatar
Well, it is darker in its color than my stocker, but I attributed that to having seen 15k miles of "cam gear to chain" polishing. Also note that I have an LS3, so my stock chain looks identical to the katech unit in the picture above instead of the visually differentiable LS1 chain. My cloyes chain looks like the cloyes chain pictured, but as I had said previously, the only "obvious" difference is its coloration
Old Jan 2, 2009 | 02:34 PM
  #131
405HP_Z06's Avatar
Understand, but there is a definite difference in link thickness between the Cloyes and Katech. The Cloyes has thicker links. Can you measure them?
Old Jan 2, 2009 | 02:45 PM
  #132
1.8t's Avatar
I retract my current statement. After looking at them side by side in the pictures, the Cloyes does look beefier:
Cloyes chain on the right, stock chain on the left
Old Jan 2, 2009 | 02:51 PM
  #133
See5's Avatar
As to the mystery black piece- not plastic?
What was the Cloyes part number for the new chain?
Thanks,
Bruce
Old Jan 2, 2009 | 02:52 PM
  #134
1.8t's Avatar
Thanks,
Bruce
If that black piece is plastic, it is the hardest plastic I have ever tried to deform.
The Cloyes part number is 9-194.
Old Jan 2, 2009 | 03:17 PM
  #135
405HP_Z06's Avatar
Yep, definite difference between the two. The Cloyes is beefier.
Old Jan 2, 2009 | 04:12 PM
  #136
vettenuts's Avatar
Also remember, not only thickness but material properties are much different as well and likely play a larger role. The Cloyes chain that you bought has also been shot peened and blue printed.
As for that black piece, it looks like a little pointer from a dial indicator.
Old Jan 2, 2009 | 04:41 PM
  #137
405HP_Z06's Avatar
Yes sir, after all the discussion concerning this chain in this thread, I thought those additional non-visible characteristics went without saying.
Old Jan 2, 2009 | 05:05 PM
  #138
1.8t's Avatar
Ok, the black piece is indeed plastic. I had to dig through my bucket of parts to find it(the pictures taken were before I even got the heads off) and after I found it, it was pretty easy to tell it was plastic. Can someone tell me how the f@#$ a plastic piece like that can make it into and on of my #5 intake valve?? Nothing on the car has ever been removed since the cam install 8k miles ago.
Old Jan 2, 2009 | 07:46 PM
  #139
DrkPhx's Avatar
Wow, the Cloyes chain looks much stronger compared to the stock chain. What is the price? Just a guess; is the black plastic piece part of the damper that broke off?
Old Jan 2, 2009 | 08:02 PM
  #140
1.8t's Avatar
No, but it wouldn't matter anyways, because there is no way for anything from the lower end of the motor to be able to make its way into the intake mani and down on top of my intake valve.
That cloyes chain was $380 shipped....and yes, that price is just for the chain.
