Injectors
Old Dec 27, 2008 | 06:38 PM
sadegna's Avatar
Default Injectors
are the green tops 42lb the same for LS2 & LS1.
http://www.intengineering.com/Shop/C...id/0/SFV/32093
Would these fit on the LS2?
Old Dec 27, 2008 | 07:05 PM
njc.corp's Avatar
i am pretty sure the injector will work but---
u will need a ev6 to ev1 connector,pig tail etc etc
and also the right o-ring that goes into the ls2 intake-
Old Dec 27, 2008 | 07:41 PM
sadegna's Avatar
I'm putting a FAST intake in,
what is this ev6 to ev1 connector?
Old Dec 27, 2008 | 07:52 PM
njc.corp's Avatar
Smile
okay well i am only going by the gto and ls2 in your sign ?-
u will have a ev6 plug on the injectors u have now-it came out that way from the factory-
going by the pictures of the injector u posted up that looks like a ev1 plug-
hence why u need the injector pigtail-unless u can get 41 pound injectors with ev6 plugs-
which i have not looked into-
u wont have a problem putting those injectors in the fast intake -u might need some fuel rail spacers for the factory fuel rail as the 42 pounders vs the ls2 injectors are taller-
I hope i am making sense-
Old Dec 27, 2008 | 07:55 PM
sadegna's Avatar
Originally Posted by njc.corp
okay well i am only going by the gto and ls2 ?-
u will have a ev6 plug on the injectors u have no-it came out that way from the factory-
Don't know that much about these plugs.
What else do I have to buy to get these injectors in? If you can post a link to that
Old Dec 28, 2008 | 04:42 AM
njc.corp's Avatar
https://ls1tech.com/forums/generatio...76-intake.html
just some light reading-
Old Dec 28, 2008 | 04:53 PM
HSV-GTS-300's Avatar
The Green tops (EV1) are longer and have a different lower O ring V LS2 (EV6).
To fit green tops to an LS2 you need this O'Ring & Spacer Kit.
Here's the full instructions for fitting.
http://www.howtogto.com/kb/Article.aspx?id=10360
You also need a set of 8 injector pigtails, to go from your EV6 harness to EV1
injectors.
KAT-A4756 - For using a LS1/LS6 injector with a LS2/LS7 harness.
