STILL have problems with my TSP 402.
Fuel pump went 70 miles ago (3 1/2 year old Racetronix with ~55K miles; I thought I got the pump before that).
Had a tapping/ticking noise come and go since I originally picked the car up. I was told it was most likely the LS7 lifters seating. I've also had ~20 psi oil pressure at warm idle from day 1.
Earlier tonight the car threw a misfire SES (running NGK TR6's) and the ticking/tapping noise got fairly audible accompanied by a NOTICEABLE increase in vibration from the motor
The clutch is a brand new OZ 700 BTW.I don't know WTF is going on now. I'm probably gonna order another oil pump even though the pump I have now is a TSP ported LS6.
Would a bad lifter cause the noise/vibration? I was afraid to drive it after that (it was vibrating pretty hard and idleing quite rough).
I'm about at the end of my patience with this whole thing.
Thanks for any help.
Why change the oil pump?
Are all the pulleys tight especially the crank pulley? See if that serpentine looks like its not moving at all when its running, as in going around everything perfectly straight, no wobble.
The ticking/tapping......I wouldn't drive it anymore until I pulled the valve covers and checked everything.
Anyway I brought that story up as it also had a loud valvetrain due to the o-ring pulling in crankcase vapors/air along with whatever oil it could grab, the air bubbles travel through the oil galleries and into the lifters. With the oil dispersed from the lifters and replaced with an oil and air mixture the lifters cannot do their job correctly, hence the lifter noise.
You would not believe how many calls I get on low oil pressure being that o-ring, sometimes several each week... Chris, PM me if you need a walkthrough or any tips.
I'm gonna tell them about the o-ring possibility. They are the guys recommending that I buy a new pump. My current pump IS ~3 years old but I NEVER had ANY issues with it on the old motor (always had perfect pressure).
Am I misplacing my trust in their competence to do the work? I'm just past frustrated with this never-ending dilemma.
Since they had to space out your windage tray for the 4" crank (hopefully they did it), you have to bend/extend the hole in the pickup tube to make it line up right in the front. You also have to make sure the tube is the correct distance away from the bottom of the oil pan. You can put the o-ring on, mount the tube, then force it into the pump without modifying it, but you are ASKING for trouble from the o-ring. If that o-ring leaks, it sucks in air along with your oil, which compresses and drops your pressure.
Your pump is probably fine, but I would be putting a new pump on anyway depending on the mileage. They are cheap. I would BE THERE when they pull that tube out. If they screwed it up, they are going to say it's the pump.
It's just odd that I had 45 psi at 185 but 20 at 205.
They told me the lifters were noisy because of the oil pressure. Shop is in my sig.
It would suck to put a new pump in and nothing changes.
I have no doubt that the o-ring is where your problems are at. I've done many of those engines and I always have about 15-20psi more than what you are seeing, with no lifter noise...
If it was me I probably would just do the o-ring myself and forget about the shop so that you can see firsthand where the issue is. Take some pics, I promise not to say "Told ya so" when it's fixed!
I'll wait to get it back and see if the problem is gone; if not I'll deal with everything at that time.
If I had the tools and time I'd try it myself even if I took me all day. This company has built LOTS of LS-based motors and cars . . . As I said . . . I'll just have to wait and see what transpires
Side note: UPS already tried to deliver your overnight parts and it says nobody was available to accept the package.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Hope that fixes the issues for ya.
It's crazy that I spent ~$50 extra to overnight it from Texas to Fl and nobodys gonna work on my car today anyway.
PM me if you need any help. Hell, we could do it ourselves, just yank the balance and the cover and loosen all the oil pan bolts. Pretty easy.
