ati super damper install gto
need help on putting the hub of the ati balancer on a callies crank. just asking around how you guys with the ati got it on thanks..
ATI has a very specific interference fit. Measure first before attempting installation because if you are out of their interference range you may need to hone the hub of the damper. On my Vette, from memory the interference fit was 0.0005"-0.0009". It should be in your instructions.
I made a tool but have since bought the Kent-Moore tool because it is used for the crankshaft timing sprocket installation as well. Here is the tool I made:
![](http://members.***.net/vettenuts/balancertool.jpg)
Did you get the pin kit as well?
