Dry sleeved allum. Ls2 block by RED ?
What is the safest/largest bore size and stroke that can be fit into this Block for 90% street use 10% track? And what are the cubes based on that bore and stroke?
Thanks Rich
Thanks Rich
Chris,
Is the sleeve longer to accomidate the 4.250 stroke or do you get special pistons for it? What are your power expectations from this combo? Do you expect to turn more that 6k rpm with it. I amagine it should have a very broad torque curve. Im not the most educated individual with this stuff, trying to learn and interested in big cube N/A engines.
Thanks Rich
Thanks Rich
I flew out and met Steve @ his shop, top notch !
He mentioned that the max for a dry bore is 4.185, which is what he did for me.
4.2 is the max for the Darton MID wet sleeve. Also the sleeves are longer and he notches them for the rods.
Attached is a couple of pics of the block.
I've put about 2K miles on it (weather sucks in the midwest) and so far 0 problems
Burlington Performance (Kansas City) put together the short block and said that the machine work on the block was excellent.
The sleeves are slightly longer, one of the options with re-sleeving
and they are custom Wiseco pistons.
Yes this should spin to 7200 rpm's and we're hoping for as much power as we can get before it runs out of intake..
But going into a car with a heavy rear and twin disk that has a race weight of 4050lbs so it wont be a dyno queen but we hope to see north of 600 with gobs and gobs of torque. (goal was 650)
But as stated there are other options, this is what we went with.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
awesome build. that is what I wanted to do with mine before my car caught on fire... 4.185 wet sleeve with 4.125 crank.
you on mofbody.com?
