Weight diffrence between Warhawk and LSX??
Old Jan 24, 2009 | 07:23 AM
venom ws7's Avatar
Question Weight diffrence between Warhawk and LSX??
How much lighter is the Warhawk block than LSX Block???
Thanks.
Old Jan 24, 2009 | 04:42 PM
EPP's Avatar
EPP
The Warhawk block with main bearing caps is 98 pounds. The LSX is somewhere around 225 pounds. Bob
Old Jan 26, 2009 | 03:51 AM
venom ws7's Avatar
Thanks Bob.
LSX Is heavy SOB.
Old Jan 26, 2009 | 05:12 AM
the_merv's Avatar
Veteran: Air Force
I've read in a few places that the LSX has some decent weight ontop of what a GM Iron Block weighs.
Old Jan 26, 2009 | 06:36 AM
drz's Avatar
drz
Yes, Iron 6.0 block weighs ~165lb.
Old Jan 26, 2009 | 07:36 AM
the_merv's Avatar
Veteran: Air Force
Damn that LSX Block is heavy..lol
Old Jan 26, 2009 | 03:22 PM
2000Hawk's Avatar
225lbs! Is that block alone, unassembled?
-Joel
Old Jan 26, 2009 | 07:01 PM
qqwqeqwrqwqtq's Avatar
Interesting that is lighter than I thought as Worlds literature lists the block at 133lbs.
The less weight the better
Old Jan 26, 2009 | 11:41 PM
drz's Avatar
drz
133lbs for the warhawk sounds more accurate after lugging one around the shop vs. a regular LS1 (85lbs with caps) It definitely has a good bit extra beef over the GM castings.
FWIW, the LSX weighs ~250lbs with the standard 3.990" bore, 225lbs sounds about right for an LSX after a visit with the boring bar.
Old Jan 27, 2009 | 06:51 AM
PaulC's Avatar
The weight of the LSX block is from the incredibly dense iron thats used to make the block. I read in Hot Rod a while ago that the tensile strength of the iron used to make the block is on the verge of being unmachineable.
"GM chose an extra-tough 280 kPa tensile strength block material (stock iron castings are 220-240, anything above 280 makes machining difficult), which not only helps rigidity but will also aid in bore durability. Features include 1045 billet steel 6-bolt main caps, two extra head bolts per cylinder (now six per hole), much thicker Siamesed cylinder walls and other beefy areas throughout to allow maximum head clamping integrity as well as distortion and twist resistance."
http://www.highperformancepontiac.co...ock/index.html
Look at me...citing sources, kinda cool?
