500+ ci LSx
Well except for a lot more tire wear.
. They also have an 898ci. monster that made a hair over 2000hp the same way!!! I WANT ONE OF THOSE TOO
I know what you mean Phil, but the motor he is talking about actually used steel rods, since it is intended for teh street, hence teh lowly 11:1 and 89 Octane.
Well, he also has a cylinder head that flows over 600CFM @ 1.10" of lift on the intake and over 400 CFM @ 1.10" of lift onteh exhaust, AND some ungodly camshaft with over 300 degrees of duration, and that is AT .050 and NOT advertised with 1.10" of lift. As Erik said, as long as the head can supply the air needed for a big cube motor, as well as the supporting camshaft, you CAN twist a big motor sky high!
Edit: I guess I was typing when you made your post Erik, or at least I did not see it...and Bruce and teh guys should be calling you this coming week
Read it and weep...Bore spacing-5.000in.
Bore- 4.751in.
Stroke- 5.7in.
Rod length-7.875in. NOT ALUMINUM
Pistons-11.0:1 BME Gas Ported
cam-600lift intake/580 exhaust- 284/314 @ 0.050
96lb/hr injectors
802 ci.
1417hp @ 7100rpm
1140lbft @ 5800rpm
Tell me this couldn't be drivn on the street, the whole point ws to make a bad street/strip motor.
Bore- 4.751in.
Stroke- 5.7in.
96lb/hr injectors
802 ci.
1417hp @ 7100rpm
1140lbft @ 5800rpm
http://www.besracing.com/632-special-crate-engines.html
And that 762ci that makes less power and torque.
And Bischoff engines are known to be some of the best built engines.
Either way though, that 60K or 80K engine must be race gas too then. So still, why such a big difference in price?
The price on his website for his (BES) 632ci 1,200 hp N/A engine is $24,000. Thats a complete engine ready to install.
Being one off parts for 800+ci engines answers that question.
