LS2 + 60cc heads, advice needed
Would like to team the 2 up, but am nervous about compression with pump gas.
Using compression calculators and 0 deck static compression is around 11.75:1 with stock gaskets. I have a f11 cam 228/230 114 lsa, but understand I will probably have to go larger to make the dcr safe.
Considering flycutting, swapping pistons or having a little taken out of the combustion chambers, but money is pretty tight at the moment.
Please chime in if you are running a similiar or have experience with a similiar combo. Thanks-Garrett
IMHO, you will be okay with 93 octane as long as your tune is spot on.
Calculation:
