View Poll Results: Which block you would run for boost?
LSX Iron Block
66
64.71%
Warhawk
25
24.51%
Other, Explain
11
10.78%
Voters: 102. You may not vote on this poll
Lsx vs warhawk
Old Jan 30, 2009 | 12:42 PM
Big Bird WS6's Avatar
MM,
what is different about the ERL block as compared to taking a ls3 block and resleeving it.
i know the 6 bolt but what else
Old Jan 30, 2009 | 12:44 PM
Alan King's Avatar
I went LSX and glad I did. I have heard of a lot of problems with the Warhawk blocks.
Old Jan 30, 2009 | 06:33 PM
HELLBENTfabrication's Avatar
warhawk is just way too much money end of story. and you still have to buy the rest of the accessories. sorry but for 5k+ prepped all that other crap better be free!
Old Jan 30, 2009 | 09:29 PM
CorvetteMajor's Avatar
7 Second/200 MPH Club
Ok here is my take both the warhawk and the lsx are excellent foundations.
The Warhawk block saves 100 lbs over the LSX. 100 lbs on the nose hurts on a Drag Radial set up. I can tell you I would make the same power with the LSX as I did with the Warhawk. I proved it to my self on the dyno. We never ran the large turbos with the LSX thats the only reason it never went 200plus with that engine. As for the droping of liners in the Warhawk I never had that issue my self I know others that had. My engine builder always makes sure the the sleves are pressed in all the way, heating the block and torquing down on it. Its not 100% but I never had an issue. The tall deck on the Warhawk is another big advantage. More room is always better. rod angle, room for a better piston design etc...
Thats my opinion
BTW My LSX engine is still for sale If you want I will put it in my car run the number pull it out and you take it with a mid to low 7 sec slip right there at the track or we could dyno it 1800 plus at the tires and pull it your choice
Old Jan 31, 2009 | 05:01 PM
SMOKINV8's Avatar
Originally Posted by MIGHTYMOUSE
other, i'm gonna pimp my erl block one more time
Are your manifolds/headers going to clear the extra bolt, or are you already planning on swapping to something else?
Old Jan 31, 2009 | 05:14 PM
MIGHTYMOUSE's Avatar
the engine was installed this time last year and the extra bolts cleared all of my stuff fine. had more problems with the moroso oil pan.
Old Jan 31, 2009 | 07:57 PM
Turbo 6.0's Avatar
Originally Posted by MY99TAWS6
From the many many builds I have read about especially on the old boosted lists I would say if you plan on running over 20psi then 6 bolt would likely be needed but certainly not for 12psi thats baby boost. Tuning of course is supposed to matter a lot more than simple amount of boost. Timing being likely the most important variable.Don't get greedy with timing.run a safe afr and should be no big problem. Also different turbos will put out different hp at same boost levels. Airflow is the true measure of power not boost.
That said running a nice big cube motor like a 427 should let you run lower boost than a smaller cube engine talking same turbo to keep the comparison meaningful.
One reason I went up to 408 from 346 to gaining more power off boost and more torque off boost. You won't be into boost that much on the street and certainly not for long.Unless you like jail! And potentially quicker spool up from the bigger cubes.
How much timing would you say is safe at various boost levels? Lets say a 9:1 comp motor running on pump gas. How much timing with 8, 12, 15 psi? This is all with about a 11-11.5 afr, a properly sized IC and NO meth.
Old Jan 31, 2009 | 08:09 PM
MY99TAWS6's Avatar
There are way too many variables . It will depend on fuel octane ,turbo,efficiency of the intercooler ,altitude,air temp...You have to find out with tuning and watching knock retard . Plugs of course are another factor.
Dyno tuning is nice as you can see effect of tuning at your different levels so you can likely go a bit less then max and still not give up much power. I find more timing seems to really help torque. Also you may find more boost with less timing is better and with meth or alc injection likely would stay closer to 10.5 to 11.0 max. Super safe timing is likely around 12 max. But with that compression would think 16 to 18 might be ok too. Again you should start lower down and move it up. For break in on my 408 combo I set max to 12psi ,afr on wideband to 10.5. Boost to 7.5. Better safe than sorry and will creep up things over this coming season. Even with forged engine I like to be careful and conservative.
Old Jan 31, 2009 | 09:28 PM
ayousef's Avatar
im surprized some people seem to like the LSX over the warhawk because of the 6bolt heads design, well wake up guys the Warhawk has a 4 and 6bolt design.
Old Jan 31, 2009 | 09:39 PM
sr71bbjr's Avatar
I think your confusedeveryone is aware that the warhawk is a 6 bolt configuration.
Old Feb 1, 2009 | 11:23 AM
BigRich954RR's Avatar
The warhawk 5 bolts are in the same spot as lsx its the 6 intake side bolt that is moved Im going to try running a 5 bolt head setup and see how much power it holds cause most leaks are around the exhaust side anyways Its a little more of a pain but a nice block after it finallly finished
Old Feb 1, 2009 | 06:07 PM
  #32
Cliff's Avatar
No one has talked about nitrous applications so I'm going to put my 2 cents in. I built a LSX 427 nasty solid roller nitrous motor. I'm tired of the heads lifting, watering the track, head bolts stripping in the aluminum block, etc with nitrous. Sure there is another 125 lbs of weight on the front but it's worth it in the long run. 6 bolts anchoring 1/2 studs into iron is a much better design then aluminum with nitrous.
Old Feb 1, 2009 | 10:24 PM
  #33
Disturbed Bird's Avatar
the warhawk has had problems with liners being dropped. after first start up.
Old Feb 1, 2009 | 10:28 PM
  #34
you have a moroso?
where you stick your filter at?
Old Feb 2, 2009 | 05:21 AM
  #35
ayousef's Avatar
Originally Posted by Shawn @ VA Speed
both the warhawk and the lsx block require some additional work to be bulletproof at 1500 hp,if you can stand the extra frt end weight go with the lsx block,it will def be cheaper in the end,i also like the way they do the additional head bolts over the warhawk design
can you please explain?
Old Feb 2, 2009 | 05:22 AM
  #36
ayousef's Avatar
note my post above.
Old Feb 2, 2009 | 05:44 AM
  #37
Worm Boy's Avatar
Your kidding right? You think that cracked cylinder walls on a lsx block @ 1100rwhp is due to the block not being strong enough?Out of all the blocks out without question the lsx is going to be the strongest.Theres really no debate. I've heard more storys about sleeves dropping in warhawk motors than i can count.Hell i'm confidant with every factory ls series block to 1000hp with some main cap attention. Sounds like something goofy went on with your motor.
I agree. We have seen several Warhawk blocks drop sleeves when they first came out. The last three we have built are still running strong. All in new Z06's making over 800rwhp, nothing crazy though. I would definately recommend going with the LSX block because you will save more than $4k than getting the Warhawk with all covers to be prepared for assembly. If you have a corvette and plan on road racing it, then I would shell out the extra cash for the Warhawk for weight distribution purposes.
Old Feb 2, 2009 | 08:29 AM
  #38
Originally Posted by Big Bird WS6
you have a moroso?
hmm can't find a pic but its relocated to the body opposite the old location with the most expensive filter adapter Kurt could find.
Old Feb 2, 2009 | 10:32 PM
  #39
well you ever get a pic. please post it. or send it my way. thanks
Old Feb 3, 2009 | 11:05 AM
  #40
Cliff's Avatar
My Moroso pan with the stock dip stick reads 1 qt low with 7 quarts. The pan is a 6 quart pan. I called Moroso about this and they said they cannot do anything about it.
