Ls7 motor, Is this a deal?
Old Jan 30, 2009 | 02:49 PM
stevecerr's Avatar
Default Ls7 motor, Is this a deal?
I have a ls7 out of an 08 vette available to me for $6500. it has 700 miles on it.
The engine has the intake, coil packs, injectors and water pump on it. Is this a good deal?
Will a Richmond 6 speed bolt up to it?
How much boost can this stock motor take?
Thanks
Old Jan 30, 2009 | 02:54 PM
Stang's Bane's Avatar
Thanks
YES,YES,YES!!!
I wouldn't put over 5-6 pounds on it personally, but that is over 800 crank hp, so you make the call..
EDIT: Not sure on the tranny question, but I think it will.
Old Jan 30, 2009 | 03:03 PM
Haans249's Avatar
Are you kidding me? Thats an INSANE price. If you don't want to take it, PM with info and I will take it.
Old Jan 30, 2009 | 03:06 PM
stevecerr's Avatar
What can be gained by a cam swap and headers in terms of rear wheel power?
What mods are suggested?
Old Jan 30, 2009 | 03:59 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
That is a heck of a deal for a full motor. We have been putting some heads and cam packages on these LS7s with some pretty good results. Depending on how aggressive you want to go we can usually get a heads and cam package put together that will put down anywhere between 560-600rwhp through a manual transmission. Send me a PM or give us a call at the shop and we can get a package quoted for you.
Old Jan 30, 2009 | 04:28 PM
JUNK's Avatar
Was considering 8500.00 for mine complete w/ dry sump tank and lines, harland sharps and clutch, so 6500 for the motor is a smokin' deal
Old Jan 30, 2009 | 04:31 PM
2000_SS's Avatar
no offense, but you're stupid for posting this and not writing the check as fast as you can $6500 is a HELL of a deal....try to talk him down to $5K
Last edited by Ragtop 99; Feb 5, 2009 at 10:45 AM. Reason: dumb ass comment removed
Old Jan 31, 2009 | 06:37 AM
Codefive's Avatar
BUY IT!!!
There was a project posted on this site last spring were a guy pulled his brand new ZO6 apart and he sold the engine (w/ under 1000 miles) for $9000
It was gone same day of him posting if that tells you anything.
IMO a cam change is almost mandatory on the LS7. The heads and intake are good pieces but the cam sucks. I wouldnt put too much boost to it, they WILL break. Like stated before, 5lbs is a good number for that engine and make sure you have a GOOD tuner.
Old Jan 31, 2009 | 08:30 AM
bowtiguy's Avatar
Originally Posted by Codefive
BUY IT!!!
not sure if who you were referringo was me, but I pulled my brand new LS7 out at 6 miles to make room for my Darton resleaved LS7 454....sold it for a tick under $11K
I'd say $6.5K is a steal. The sky is the limit on these. I'm at 572/538 with my combo ( basically stock heads less than 250 duartion and less than .650 lift) I saw a set of "hand finished" LS7 LPE heads flow over 405 on the intake side..... Those are next
Old Jan 31, 2009 | 09:15 AM
Codefive's Avatar
The guy I was refering to is here in this thread:
https://ls1tech.com/forums/forced-in...-f-1c-epp.html
Click the link in the first post. But still ... point made $9K, $11K ... either way you slice it, for $6,500, I wouldnt hesitate. In fact I'd RUN to his house before the guy changes his mind. LOL.
Old Feb 4, 2009 | 02:20 PM
garys 68's Avatar
I'll take 2 at that price..
As for the Richmond, It will fit. The LS7 should have the correct pilot bearing already in place. I got my bell housing from Keisler. It's a 621 BBC with the extra hole for the top trans mount. If you use a manual clutch linkage, I can give you details on the throwout bearing setup.
Old Feb 4, 2009 | 04:31 PM
NemeSS's Avatar
not a good deal at all,
send it to me asap
Old Feb 4, 2009 | 10:48 PM
RE AND CHERYL's Avatar
He's rippin your *** off, let me have his name and I'll get you a better deal.
Re'
Old Feb 5, 2009 | 10:46 AM
Ragtop 99's Avatar
Dibs! I guess that makes me first in line.
