427 build...
Old Feb 11, 2009 | 10:28 PM
BAM-BAM's Avatar
Default 427 build...
was specing out a cam for my new build ..came up with a 253/257 .623/.623 on a 113 +3 what do ya think of this cam for my setup?
here is the rest of the setup
ls7 block
etp 245's 62 cc.... cr of 11.8 to 12.0 depending on gasket..
92 fast
kooks 1 7/8 lt
4000 stall
9 inch with 3.89
asp pulleys
etc etc.
Old Feb 12, 2009 | 08:12 AM
Gen414's Avatar
ls7 block
92 fast
kooks 1 7/8 lt
4000 stall
9 inch with 3.89
asp pulleys
etc etc.
What is it going in, weight? Your intentions?
Old Feb 12, 2009 | 10:04 AM
BAM-BAM's Avatar
98 camaro...full weight car...75% track 25% to the track maybe the occasional cruise..
Old Feb 12, 2009 | 10:46 AM
CamaroSS22's Avatar
With that cam and those heads you should be higher in compression. I would run the stock Z06 gasket. It should be a pretty stout build. I would call either Jon or Jason as TSP and they'll set you up with something pretty good. I just ordered mine from Jon and is about the same build, I used the LS7 heads instead of the etps.
Old Feb 12, 2009 | 10:49 AM
Stang's Bane's Avatar
If you are on pump gas, I would not really go over 11.5 or so on the compression..
Old Feb 12, 2009 | 07:19 PM
03 BUSA's Avatar
Pump gas here with 12:5 compression and 24-26 degrees of timing in the last build.
Old Feb 12, 2009 | 11:45 PM
CamaroSS22's Avatar
Your static compression doesnt really matter as much as your dynamic. If your dynamic is aroun 8.6 you should be fine on 93. I had a DCR of 8.8 on my 403 and a static of 11.5 and i ran 30 degrees of timing all day with no problems. With that cam you should have no problem on pump gas.
Old Feb 13, 2009 | 01:40 AM
Haans249's Avatar
Here we go again with DCR...
 Michael S. Palmer
Old Feb 13, 2009 | 06:12 AM
No doubt, some people need to step away from the internet
Old Feb 13, 2009 | 02:06 PM
Gen414's Avatar
If you are in teh area of 12:1 that cam would probaly be right. 250 ish @ .050 with .6xx is the target area. I personally would run a bit more lift than what you have listed, like in the .650 range, but I like lift My 414" is 12:1 and I am hooked up on a solid roller in teh 260/270 range with almost .800 on a 110 (and when I say almost .800, it is in the area of .750/.760)
