LS7 into WS6
Old Feb 13, 2009 | 08:18 PM
PONTIAC SLP's Avatar
Default LS7 into WS6
Hi guys , i'm wondering if i want to install an LS7 engine into WS6 what i need to complete this setup ? i heared from my buddy i should install a dry sump ? is this true ?
Old Feb 13, 2009 | 08:34 PM
Tom@SpeedInc's Avatar
I most likely wouldn't install with dry sump, depends on your budget.
Old Feb 13, 2009 | 08:42 PM
can i install the LS7 with oil pump into WS6 ?
Old Feb 13, 2009 | 09:48 PM
03 BUSA's Avatar
Yes, you can have it the same way your current setup is. I have been for 2 years no issues. It's really no different than a normal motor swap. Just relocate the knock sensors to the side of the block and you will need a cam sensor extension harness. Let er eat.
Old Feb 14, 2009 | 06:44 AM
sounds good !! thanks bro
Old Feb 14, 2009 | 12:15 PM
yes/no you will need to run all C6Z accessories due to the belt position with C6Z06 dry sump, the balancer is out further with the larger oil pump. IMO its impossible to fit in an Fbody, i've seen it done with extensive amounts of work into few GTOs.
IMO I would run an ARE dry sump setup instead of LS7 anyway, and if thats not budgetable just run factory LS1 oil pump/pan pickup, you can make your factory balancer work with LS7 crankshaft, provided you use LS2 timing set.
hope this helps
Old Feb 14, 2009 | 05:25 PM
yes/no you will need to run all C6Z accessories due to the belt position, the balancer is out further with the larger oil pump. IMO its impossible to fit in an Fbody, i've seen it done with extensive amounts of work into few GTOs.
hope this helps
yes thanks M.R freezer
