402 vs 416
Old Feb 19, 2009 | 11:33 AM
Bill00Formula's Avatar
Recently there was a member that uses the name Pray that had a 416 that made 573 at the wheels, probably the same guy. He had TFS 235, 12 to 1 compression. You can probably find it through the search.
Old Feb 19, 2009 | 05:43 PM
blu byu EH's Avatar
Originally Posted by 6.0monsta
Well I will stay NA. NO N20 or FI.
I have as cast Trickflow 220cc heads. I'm thinking along the lines of a 236/238 600ish cam. I have an A4. Want as much power as I can get while still ensuring I don't get any surging or bucking with the cam. I have to maintain good street manners.
Not sure I believe the 1.27/ci. That would mean I'd gain 50whp going from 364 to 403. I think most only gain around 17 with the same jump?
Go to Vengeance to get it tune. They take as long as it takes to make sure that the car is right.
Old Feb 19, 2009 | 06:08 PM
6.0monsta's Avatar
I live in Texas man. GA is a hike.
I ordered a 416 through Va Speed. It was a hard choice and I had to do a lot of research to come to that decision. But I finally placed the order.
Old Feb 19, 2009 | 09:14 PM
LS6427's Avatar
I'd like to see that dyno sheet. A 573 RWHP 416 has to be pretty radical.
What intake?
Old Feb 19, 2009 | 09:27 PM
Here is the car.
https://ls1tech.com/forums/vehicles-...en-02-z06.html
Old Feb 19, 2009 | 09:36 PM
TJ's Avatar
TJ
Originally Posted by dug
go for the 416. It will make a lil more power and have a lil smoother idle.
how will a 416 have a smoother idle over a 402?
only way i can see this happening is both motors with the same camshaft.
the inches will "eat" the cam, making it have better manners so to speak.
it can be 4 inches or 900 inches. i dont see the light in your statement.
Old Feb 19, 2009 | 10:44 PM
LS6427's Avatar
The longer the stroke, the smoother the idle....as I've always understood it.
But how much longer can a stroke possibly be with any stroke/bore combo between a 402 and a 416...not much.
Old Feb 20, 2009 | 07:59 AM
lstvr's Avatar
Heres my 416 idle with a MUCH bigger cam
Old Feb 20, 2009 | 01:46 PM
LS6427's Avatar
MUch bigger than who's cam?
Old Feb 20, 2009 | 02:00 PM
lstvr's Avatar
Than the bloke who is asking on this thread!
Old Feb 20, 2009 | 03:26 PM
6.0monsta's Avatar
So do you think a 236/238 600ish 112 cam is too small for a 416? I have an auto.
Old Feb 20, 2009 | 06:37 PM
  #32
LS6427's Avatar
416's generally put down around 480-530. 573 RWHP, I highly doubt that it made that much true RWHP. Maybe on that dyno it did. There's nothing about his build that puts it way ahead of any other 416ci out there, that I can see. 573 RWHP is enough to do alot better than a 10.21. 10.21 only requires about 480-500 RWHP in that car with a good hook.
I'd like to see that car on another dyno. 427 C6 Z06's with ported LS7 heads, cam upgrades and exhaust work and a tune are having trouble making 570 RWHP. There are some that I've seen over 600, but most are in that 570-580 area.
Old Feb 20, 2009 | 06:49 PM
  #33
WKMCD's Avatar
402 and 416 both have a 4 inch stroke.
The additional bore will help with any valve shrouding you may have depending on what heads you run.
Go with the 416.
Old Feb 21, 2009 | 02:57 PM
  #34
mike c.'s Avatar
For 17hp,I would pay the $400.00. The new fast intake for my L92's will be $1,000 and I'll pay it for 25hp.
Old Feb 21, 2009 | 03:38 PM
  #35
LS6427's Avatar
Go with the 416.
It was more of a general statement.
402 = 4 bore x 4 stroke
~416 (415) = 4 bore x 4.125 stroke
All else being equal, the 416 will make more torque.
So...............
Old Feb 21, 2009 | 06:20 PM
  #36
I also assumed it was discussion between a LS2 block versus an LS3 block based motor, different bores same stroke.
Old Feb 21, 2009 | 07:39 PM
  #37
blu byu EH's Avatar
That nothing. I drove over 1,200 mile one way from MN in a snow storm to make sure that my car will last and make the power it should. I did drive the camaro and when I got hour 1 1/2 out of St. louis my SLP loudmouth exhaust broke and I had to deal with open headers and y-pipe. That Fing sucked
Old Feb 22, 2009 | 07:40 AM
  #38
WKMCD's Avatar
I'd bet the great majority of 416-418 are built with the LS3/L92 block. Very few are going to run 4.125 stroke in an LS2 block.
So
Old Feb 22, 2009 | 09:13 AM
  #39
dug's Avatar
dug
my 230 114 cam idled smoother than a 222 112 cam. If you want a smoother idle go for the 114lsa
Old Feb 22, 2009 | 09:40 AM
  #40
JakeFusion's Avatar
Super Hulk Smash
So
It's not entirely a good idea to run a 4.125" on the LS2 block. It has a slightly shorter skirt depth than the LS1 - that's why you see 4.100" strokes in LS2s. A 416 is LS3 based... 4.070" bore.
I'd run the 416 over the LS2 based 402. It'll unshroud the valves more and allow a head like the TFS235 to make a little more power.
A mid 230s duration cam would be pretty mild in that size motor. A cam that would act "cammed" but still be extremely livable would be a mid 240s duration cam and would perform better.
