Compression help for ls2 427?
Old Feb 19, 2009 | 07:13 PM
NVR4GET's Avatar
Default Compression help for ls2 427?
I Just got new heads for my motor and need to know the compression it will be. I have a 4.125in. ls2 sleeved block with a 4.0inch crank. Just ordered 4.125 cometic head gaskets that are .040" thick and the heads are 65cc. I have 6.125 rods and wisco pistons with -8 dish. I do not know the deck height so is there any way to figure it out?
Thanks,
Matt
Old Feb 19, 2009 | 07:29 PM
CamaroSS22's Avatar
if you give me the cam specs i can give you the dcr too. Your static should be around 11.92:1.
Old Feb 19, 2009 | 07:54 PM
Haans249's Avatar
First off, your gaskets are not large enough. You should have atleast 4.130" bore gaskets, and I would recommend 4.150 (which is the stock LS7 gasket bore size). The bore is going to be larger than 4.125" remember, for piston clearance.
Secondly, without your deck height, there is no way to tell what your compression is going to be. But assuming a zero deck height your compression will be 11.73:1 SCR.
To measure your deck height, put a straight edge over the piston, and turn the piston till it touches your straight edge. Then, using a dial guage, place it at a 90 degree angle at the pin side (middle left or right) of the piston. Zero your dial guage, then rotate the motor and watch till the needle goes up and then starts to go back down. Whatever the highest the needle went is how far the piston comes out of the hole, and this is your deck height. Get this measurement, and I will get you the correct compression value.
Old Feb 19, 2009 | 10:06 PM
405HP_Z06's Avatar
I assume your using Wiseco piston part # K395X125 which has a '0' piston to deck height with a stock 9.240" block deck height.
I agree with Haans249, you should go with at least a 4.150 head gasket bore diameter.
Here's the calculation:
Old Feb 20, 2009 | 12:28 AM
NVR4GET's Avatar
Thanks guys, I am changing my order for the head gaskets.
Matt
