LS1 vs LS2 cam bearing difference
Old Feb 20, 2009 | 03:49 PM
jfm's Avatar
jfm
Default LS1 vs LS2 cam bearing difference
I see there are 2 different part numbers for LS1 and LS2 cam bearings I was wondering why they are different. Amybody know?
Old Feb 22, 2009 | 12:42 AM
JUNK's Avatar
The ls1/ls6 cam has the reluctor for the CPS at the rear bearing journal, the ls2,3,7&9 have no reluctor on the cam, but on the cam gear. U can put the ls1/6 cam in all others, but to put a factory Ls2/7 style cam in a ls1 u need to use the ls2 timing cover, cam gear, and adaptor harness for the CPS.
Old Feb 22, 2009 | 09:36 AM
JFM-jr's Avatar
So to put an LS1 camshaft into an LS2 block what bearing set should I use? I know about the gear and pickup etc just need to order cam bearings. Reusing my G5X4 in my LS2.
Old Feb 22, 2009 | 10:28 AM
ddcarter's Avatar
You need to use the bearings for the block. LS2 bearings in LS2 block.
Old Feb 22, 2009 | 04:10 PM
JFM-jr's Avatar
ahh got it now thanks for the help guys.
