View Poll Results: rpm rev limiter
6600 rpm's or less
15.38%
6700-6900
32.05%
7000-7200
29.49%
7300-7500
11.54%
7600-7800
2.56%
7900 rpm's or greater
8.97%
Voters: 78. You may not vote on this poll
What is the rev limiter on your big cube/stroker motor?
Old 06-10-2009, 08:36 AM
  #41
7 Second Club
Phil99vette's Avatar
438", Turbo, LSx with main girdle, 9000rpms.
Old 06-14-2009, 11:24 AM
  #42
racer7088's Avatar
The valvetrain is what will set your rev limit 99 per cent of the time.
Old 06-19-2009, 08:31 PM
  #43
Pwebbz28's Avatar
414 with L92 heads and gmpp intake. Pulls to 8k. Solid roller with DRE shaft mounts.
Old 06-20-2009, 02:25 PM
  #44
99blancoSS's Avatar
I think the question should have been asked what is the limit of your hydraulic lifter big cube/stroker ?
Old 06-20-2009, 03:38 PM
  #45
7 Second Club
What kind of application is the motor intended for? F/I:NA, Street,Street/strip,Strip only
Old 07-02-2009, 02:46 PM
  #46
ColeGTO's Avatar
Rev limiter set at 8400, shift at 8200.
403ci SBC - N/A 4.135" bore - 3.75" stroke
Motown Iron Block w/ Billet Caps
COMP Solid Roller - 286/292 @ .050" .750"/.730" 112° lobe
Smith Brothers 5/16" .080 wall pushrods
JESEL Pro Series Shaft Rockers
ISKY Red Zone Solid Roller Lifters .842" dia.
ISKY 9945 Springs - 300 lbs. seat - 700 lbs. open
DelWest Ti Intake and Exhaust Valves
DelWest Ti Retainers
As a note, I built the engine 2 years ago in my garage, dyno'd it, put it in the car and have made aprox. 100 passes and have yet to need to adjust the valve lash from the original .028" cold. It just goes to show you that if you have a stable valve train, adjustments are a thing of the past. Don't get me wrong, I check it after every 5 passes, but I haven't needed to turn a wrench yet. Valve adjustment is an excellent way of detecting a valve train problem before it becomes a bigger issue.
Finally after 100 passes, 20 dyno pulls, and about 40 street miles we broke a valve spring at the track last weekend. I'd say that was pretty damn good considering how stressed the springs are. And I checked the lash to be sure we didn't bend a valve, and it's still good. Amazing, since our PTV is only .080".
Cole
Quick Reply: What is the rev limiter on your big cube/stroker motor?
