How much compression can I run? LS2/L92 setup
Old Feb 25, 2009 | 10:02 PM
Danny's Avatar
Default How much compression can I run? LS2/L92 setup
Hey guys,
I'm getting ready to slap on a set of L92 heads on my 05 C6. Haven't gotten my cam yet but it will be something around a 224/228 with no more than .600 lift. The car is a daily driver so reliability is a must.
My question is:
How much compression can I run on pump gas (91 octane)? The higher the better so i can retain as much bottom end power.
I know the pistons will need to be fly cut & heads will need to be milled.
Thanks guys
Old Feb 26, 2009 | 02:28 PM
JUNK's Avatar
We are getting away w/ 12.5:1 on the ls7s using 93 oct. and 23x or 24x cams. I run 11.9:1 myself on stroked street LS7, 22* timing and 93 octane. No issues....
Old Feb 26, 2009 | 02:40 PM
SlwSVT's Avatar
With a 224 / 228 cam you may not need to flycut the pistons. You may also just be able to use cometic thinner head gaskets and get the compression bump you need. 11.5 - 11.75 to 1 should still be fine on pump gas.
Old Feb 26, 2009 | 03:16 PM
1.8t's Avatar
I would be worried about PTV clearance before I would be worried about compression. Fly cutting may be in order depending on the cam.
Old Feb 27, 2009 | 11:10 AM
Danny's Avatar
Ya i'm almost positive I'm going to have to flycut the pistons.
I think i'll go with 11.5:1 or 11.75:1 just because i only have access to 91 octane here in SoCali.
Thanks for your help guys.
Old Feb 27, 2009 | 01:07 PM
lifted99GMC's Avatar
Im running forged pistons with reliefs, but milled heads .055", and it has right at 13:1 CR, runs on 93, with 244/248 cam. L92's love compression
Old Feb 27, 2009 | 05:21 PM
Danny's Avatar
So what do these heads like better?
smaller cams like a 224/228 or something bigger like a 232/236?
I want something that can keep a good amount of bottom end torque but screams up top. This will also be going into a daily driver so i don't want any surging or shaking.
LG motorsports is recommending me to go with their G6X3 Executive cam.
Thanks for all your opinions guys.
Old Feb 27, 2009 | 06:29 PM
WKMCD's Avatar
These heads love timing - more so than the cathedral port heads. Give up some CR and add timing to make HP. They will still produce great low/mid power.
Just my $.02
Been there - done that.
Old Feb 28, 2009 | 02:28 PM
Danny's Avatar
So would 11.0:1 be good enough to add more timing?
Old Feb 28, 2009 | 05:23 PM
WKMCD's Avatar
Yup! You should be able to get around 30 degrees of lead at 11:1
Old Mar 1, 2009 | 10:25 AM
Ragtop 99's Avatar
Haven't gotten my cam yet but it will be something around a 224/228 ... I think i'll go with 11.5:1 or 11.75:1 just because i only have access to 91 octane here in SoCali.
Timing does seem to help a lot. Keep the IVC a bit later and you'll be able to run a bit more timing and pull to a 7k shift. Maybe something like a 228/228 114 114
Good luck
EDIT: I have not evaluated PTV for the suggested cam. got to be carefull if you do not end up fly cutting.
