Heads on L76 engine, L76 vs L92 ?
Old Feb 26, 2009 | 03:12 PM
Hakonsen-Racing's Avatar
Default Heads on L76 engine, L76 vs L92 ?
I have been looking for engine for my Fomula Offroad car and was planning
a build based on the L92 engine. But know i have found a L76 at a good price
and some questions came up:
Which heads are used on the L76 engine, is it the L92?
Beside that they are 6.0 vs 6.2 l, what do you guys thing
are the Pros and Cons between these engines?
Regards Kjetil
Norwegian Formula Offroad Racer
www.haakonsen-racing.com
Old Feb 26, 2009 | 03:30 PM
NemeSS's Avatar
L76 AND L92 use same heads design, as does LS3, they may just differ in part numbers, 823 is common casting for l76/l92/ls3 but there are others.
l76 and ls3 intakes are very similiar, l92 truck use hi rise version intake
6.0 and 6.2 engines came equippd with l92 type heads
Old Feb 26, 2009 | 08:40 PM
alocker's Avatar
L76 has DOD (AFM) and requires a different valley pan, lifters, and some other stuff for a cam swap. Both have VVT. L76 intake and throttle body setup is more desirable.
