View Poll Results: Lunati Crank or Rotating assembly
Lunati Crankshaft for 1200
23
65.71%
Full rotating Assembly for 1500
12
34.29%
Voters: 35. You may not vote on this poll
Lunati or Eagle Crankshaft?
Old Mar 5, 2009 | 02:14 PM
sschoeffler's Avatar
Default Lunati or Eagle Crankshaft?
I know peeps would say Lunati, But whats the main difference between the two? I can pick up a Lunati Crankshaft for 1200 used for 1200 or I can get Full rotating assembly fith an eagle crank, eagle rods, JE pistons, ARP main bolts, ARP Rod bolts, piston rings, main bearings and rod bearings for 1500 shipped all brand new. Help me make a decision.
Old Mar 5, 2009 | 02:39 PM
Cliff's Avatar
There is nothing wrong with Eagle, until you compare them side by side. Then you can see why Lunati has the reputation for excellence.
Old Mar 5, 2009 | 03:12 PM
smok'nZ's Avatar
MASS seller approved
eagle unless i was building a 1000+rwhp motor thats what i would use
Old Mar 5, 2009 | 04:07 PM
LS6427's Avatar
What kind of power are you going for?
Less than 700 RWHP. Stay with the stock crank and just buy the other forged stuff and save even more money.
More than 700 RWHP, think about a forged crank.
Old Mar 5, 2009 | 04:35 PM
I am going with a 408 stroker so I need the 4" crank
Old Mar 5, 2009 | 04:37 PM
Tom@SpeedInc's Avatar
Compstar?
Old Mar 5, 2009 | 06:43 PM
Shawn @ VA Speed's Avatar
How much hp?
Old Mar 5, 2009 | 06:49 PM
02 BLK WS6's Avatar
Compstar or Lunati
Flame away, but I've heard about too many Eagle cranks breaking (mostly big blocks).
Old Mar 5, 2009 | 07:59 PM
Originally Posted by Shawn @ VA Speed
How much hp?
Looking for about 750 RWHP
Old Mar 6, 2009 | 12:55 AM
LS6427's Avatar
Lunati
Old Mar 6, 2009 | 06:41 AM
i usually use a callies compstar around that hp level
Old Mar 6, 2009 | 06:52 AM
HUNTER02SS's Avatar
For 750rwhp why not go with 377ci. and stay with a stock crank??
Just buy a set of h-beam rods and forged pistons.
Old Mar 6, 2009 | 10:03 AM
mebuildit's Avatar
You get what you pay for in my opinion.
Old Mar 7, 2009 | 08:13 AM
99blancoSS's Avatar
I'm with Shawn and Fraser ... Callies Compstar is what I would use.
Old Mar 7, 2009 | 07:27 PM
Because 408 is just sexy, almost as sexy as a 427
Old Mar 30, 2009 | 10:15 AM
Black Sunshine/ 00SS's Avatar
Eagle, if that is the price balanced. Sometimes it's better to wait until you can afford to go overkill, but it sounds like you are budget minded..
As mentioned, the stock crank is pretty dam strong.
Old Mar 30, 2009 | 01:29 PM
99LS6SS's Avatar
Is it possible to have the stock crank lightened? How much would something like that cost?
Old Mar 30, 2009 | 09:23 PM
firefighting1101's Avatar
i went with callies compstar...and im just a tad above that range
Old Apr 5, 2009 | 02:13 PM
03supercobra's Avatar
Compstar also.
Old Apr 5, 2009 | 02:41 PM
MrElectric03's Avatar
I dont think the eagle would be bad but you need to have the bearing surfaces checked. I was told the edges are rounded and need to be cleaned up before they eat your bearings.
Thats a good deal and all but personally id go with a compstar in that price range.
