look what i found.. is this a bad sign?
is this a bad sign or is it because the all the heat that the stroker is producing and its just releasing to where the breather filter is...
I took off the filler cam and could not see no sluge or nothing and i also took off the throttle body to see if there was any oil or sludge and nothing.
I would be VERY concerned if I were you. Drain your oil as well and inspect for bearing material, if you find a fine metallic gold dust, say hello to a rebuild. Also, cut open your oil filter and look for metal in there as well.
If you are concerned, drain the oil, if its clean then its just water in the air.
also, you might try a catch can. not sure if it will help, but it's worth a try.
i hear good things about the mike norris catch cans.
ttp://www.mikenorrismotorsports.com/Billet_PCV_Catch_Cans.html
Go for a 30 minute drive, then pull over and take a look, it should be gone.
