l92 head question
These have an offset intake piece.
The L98 is the 6.0L fitted to the Lumina and Caprice SS. These are the same head castings as the L92. You will also need the L76 intake which is also found on the Lumina and Caprice as these heads and intake go together and will then fit on the LS2 block.
p.s. Use the valve springs from the LS2 heads as they are better.
PM me as I'm after LS2 type heads.
https://ls1tech.com/forums/generatio...weeper-ht.html
Gerry
Gerry
Yeah, I looked at Yella, but here was the problem:
I could not get a straight answer from them. I originally called, and asked for an adjustable rocker (in @ Oct of last year) and they said they would debut it @ end of Dec, first of Jan. for $500-$600. So, I waited (and my build) for 'em. Then I called end of Dec, and they said that the rocker they just came out with would now NOT work for my spring pressure
That I needed their OTHER rocker assembly that would not be out until April or May
Why they did not know that when I first called back in Oct, I will never know. So, I stepped up and bought some T&D shaft. The rocker assemblies for L92 are scarce (but are getting better).T&D or Comp is what I vote for. That being said, I have not heard any bad things about the machining or quality of Yella, and they are cheaper ($$$$) than T&D or Comp
sid447 ok would i really gain 15 hp from 1.85 rockers or u suggest i stay with the 1.7 standard rockers, and yeah sorry but i need my ls2 stock head for my other project .
shoddy dogg how much did u pay for them cuz i found a crane rockers for 800$???!!!
gin thanks alot for the helpfull info bro
http://www.sdpc2000.com/product/1256...ArmIntake.aspx
You will also need new rocker stands. ($8/ea)
http://www.sdpc2000.com/product/1260...rmSupport.aspx
sweet10s10v8
guys i really appreciate ur help dam i didnt know about these fitment kit so in total apprx. it will be 550 $ would it be hard to fit these 2 kits with my stock rockers?? or any medium work shop can do it .
and 1 last q what head gasket will should i buy ls2 stock gasket or l92 gasket ??
One of the biggest complaints about the stock rockers was that even stock, there was a lot of clatter in my LS2...sounded like a sewing machine. After installing my L92s with Yella Terras, the valvetrain is more quiet than it was stock. I have 20,000+ miles on my setup without a problem...90,000 miles on the bottom end.
Don't know if anyone has mentioned it yet, but along with a different intake manifold, if you plan to use your stock LS2 fuel rails, you will also need new injectors. At least that's what I did to use my LS2 fuel rails. I purchased the FAST 39# injectors, but you might want to go bigger if you plan on putting down more hp than say 500. Not sure what the rest of your mods/future plans are, but on the coldest days, I've seen low 70% duty on the 39#s at 438 hp.
Gerry
Gerry
http://store.katechengines.com/share...unt2=733466744
I ran a WOT log this morning, and with the 39# injectors (cold morning) I saw 75% duty. (Smoked a BMW M3 while checking
)Gerry
