Stock LQ4 Cam options?
I am dropping an LQ4 into a 1994 F body and would like to give the engine a little bit of kick before install.
The LQ4 is out of a 2002 2500HD.
What Camshafts net the most RWHP? I was considering using a GM Hotcam but i'm sure there are much better options out there.
I dont care if I need to install springs too. I've pretty much figured that i'd have to do springs too.
What cam wakes up the LQ4 best?
Thank You
For my 6.0 LQ4, which is in a truck, I speced out a 210/218 112 +2. This cam provides the max area under the curve, a nice bump in HP, and is small enough that O2 sensors keep working. I think there was an article written in Hot Rod a couple years back where they tested a few different cams in a 6.0 L truck engine. Here is a link.
http://www.hotrod.com/techarticles/e...camshafts.html
The other cam that really shined to me was the crane 144HR00118
Anyone have either of these cams in a virtually stock LQ4 / 9
