05 gto cam
Old Apr 23, 2009 | 11:36 AM
Silver Rocket's Avatar
Default 05 gto cam
im thinkin about putting a cam in my 05 gto. i dont want it to really be noticeable tho. any ideas what kind of cam i can get?
Old Apr 24, 2009 | 10:56 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Do some searching in the dyno results section bro. Your goals decide a lot of what camshaft will work best in your application. I personally like the 228R for guys wanting a smaller camshaft, or maybe the Torquer 3 camshaft if you want a little bit more aggressive camshaft & have the supporting mods. You might also checkout the new PRC spring kit, it's designed to have a much much longer life than previous LS double valve springs & should give you years & years of trouble free miles without even thinking about valve spring maintenace typically associated with big lift aftermarket camshafts!!
http://www.texas-speed.com/shop/item...d=175&catid=49
We offer the complete cam packages even with this new valve spring for about $730ish if memory serves me correctly!!
https://ls1tech.com/forums/generatio...pring-kit.html
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Apr 25, 2009 | 02:27 PM
L98Power's Avatar
Exclamation
I am not a big expert but those will do..
those are hard to notice!
99-TR-CHEATR-CAM 399$
CheaTR 214 / 230 .601 /.575 117 LSA
99-TR-CHEATRLS2-CAM 399$
LS2 CheaTR" - 215/230 .629/.592 117 LSA
L210065297 386.95$
LS1-GT11 215 / 231 .631" / .644" 1.7 ratio 118
Old Apr 25, 2009 | 02:34 PM
L98Power's Avatar
I am sorry Jason maybe u didnt notice but he is looking for some thing that is not noticeable
Old Apr 25, 2009 | 07:40 PM
this is true, i dont want you to kno there is a cam in the car is the goal here
Old Apr 25, 2009 | 07:41 PM
L210065297 386.95$
what kind of cams are those?
Old Apr 25, 2009 | 09:01 PM
L98Power's Avatar
ok just to make things clear its the part #s the 1st 2 cams from thunder racing and the last one is by lingenfelter.
Old Apr 25, 2009 | 09:02 PM
ssick1's Avatar
nice those are good sleeper cams
Old Apr 26, 2009 | 01:46 PM
how much power will i get out of either of those cams? and am i going to need a tune after i get this installed.
out of those cams witch is going to sound less like i have a cam, the thunder raceing or the lingenfelter?
Old Apr 26, 2009 | 01:51 PM
am i going to need new springs also or can i use the stock ones?
Old Apr 26, 2009 | 03:44 PM
SweetS10V8's Avatar
You should change springs with any camshaft, no matter what. Stock LS1 springs are basically at their limits with the stock .500" lift cam. Which spring you pick will be dictated by which cam your run.
Old Apr 28, 2009 | 12:12 PM
can i have a cam made? will i have better results with that.
